Old March 2, 2007, 08:09 PM
BALISTX's Avatar
Default ASRock 775DUAL-VSTA
I friend at work recommended this board for my current situation. As you can tell by my specs I am currently running a ATI AIW 9800 Pro as well as PC2700 DDR333 memory. I want to make the switch to C2D but I can't afford to buy all the parts at once. He suggested get this board to use in the meantime as I can still run my ATI AIW 9800 Pro and use my new PC2-6400 DDR2-800 and get an C2D E4300.
I haven't been able to find any reviews but from customer reviews at NCIX they seemed to not really have any complaints.
ASRock 775DUAL-VSTA - $80.92 @ NCIX
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 2, 2007, 08:21 PM
Babrbarossa's Avatar
Good board, I guess-- just not an overclocker-- you can't adjust the voltages at all.
Here's some readin fer ya:
http://www.asrock.com/mb/overview.as...l=775Dual-VSTA
http://www.legitreviews.com/article/377/14/
http://www.hardwarezone.com/articles...?cid=6&id=1998
http://www.anandtech.com/mb/showdoc.aspx?i=2810
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old March 2, 2007, 08:29 PM
sswilson's Avatar
Certainly an interesting looking board.
I've run two Asrock mATX boards (S754) and while they had the same problem with having little ability to up CPU voltages they still did allow some OC which can't be said for a lot of the lower end mATX boards. (There's a voltage mod for the one's I've had, could be there's one for this board as well.)
Last time I looked at the Asrock site, it looked like they had a pretty decent modding community.
The only thing I'd double check on is if DDR2 800 will run on it.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old March 2, 2007, 08:32 PM
BALISTX's Avatar
No the DDR2-800MHz won't run on it but I still have my 1GB of DDR333 MHz I can run it until I upgrade to another board later on down the road.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 2, 2007, 08:37 PM
Here's a quote from the anandtech article that I linked to below- with this board, they found in real-world performance, memory wasn't a big factor. I would say that it's an excellent choice for a budget upgrade using that memory.
"This story told us the choice of components like the CPU, motherboard, or graphics card is far more important to the overall performance of the system than our memory selection on this platform. While this is not surprising and certainly not unexpected, it just reinforces the fact that at this price point you can certainly extend the life of your existing DDR memory."
Old March 2, 2007, 08:44 PM
BALISTX's Avatar
I read the article and the one from Legit reviews. From the sounds of things it's a good board, sure it's not an overclocker but to tide me over untill I have the money to afford a better GPU and mainboard I think it will do me good and I'll get some nice performance from the stock E4300
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 2, 2007, 09:16 PM
sswilson's Avatar
If you do pick one up, let us know how it works out for you.
Might be just the ticket for those of us running S939 boards who can't afford to shell out $300 on DDR2 at the same time as we upgrade our cpu+mobo.
Old March 2, 2007, 10:22 PM
BALISTX's Avatar
Oh for sure, I'll do my own review on it . It will be a couple of pays, one pay I'll get the board and the next I'll get the CPU.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 2, 2007, 10:34 PM
If you need a c2d board right now that will work and allow you to use your computer the board is perfectly fine and does what its supposed to :)
Old March 3, 2007, 01:03 AM
I was also considering this board to ease myself into C2D also but with price drops coming around April I decided to wait and get a complete new system. But if you do get this I'de really like to hear how it performs.
Comment thread for the "Asrock 4CoreDual-VSTA" review sswilson CPU's and Motherboards 16 December 18, 2007 09:04 PM
I just dumped by ASRock 4Core DualVSTA KnSKranky CPU's and Motherboards 5 November 14, 2007 01:58 PM
Asrock 4coredual-vsta - blank screen josh_45 Troubleshooting 9 May 19, 2007 11:49 AM
Using AsRock Untied Overclocking with an Intel SP79K ? lamimartin Overclocking, Tweaking and Benchmarking 0 May 4, 2007 09:28 AM
