Old March 18, 2007, 09:32 AM
Trial Member
I picked up this board and an E4300. The only grief I have had, is not being able to run my 6800gt in it.Massive problems when trying to run 3d.Currently using my my 9600xt. Going to try one more fresh install.As for overclocking, there is an excellent thread at xs on oc'ing, volt mods etc for this board.As said before,it's an affordable way to make the transition,and it's a pretty decent board.I run mine at 2.4ghz, 30c temp.
Old March 24, 2007, 09:28 AM
Fallen Folder
A few of my folding teamates are using this mobo and e4300 for a very cost effective upgrade to their older non dual core folding rigs.
In folding these days, c2d dual core rule running a new win SMP client from stanford. Had to remove link to stanford folding - this is my 1'st post!
I just discovered this site today ... are there many other canuck folders here?
Old April 16, 2007, 06:47 PM
sswilson's Avatar
I'll be running one of these..... http://www.asrock.com/mb/overview.as...4CoreDual-VSTA by the weekend.
I'll certainly update as to how much luck I do or do not have.
Old April 18, 2007, 03:30 PM
sswilson's Avatar
Well it works.........
Interestingly enough @ stock (I set mem to 200 vice 166) my mem runs @ ddr512. (According to cpu-z, but I'm not sure I trust those readings)
Haven't run stability tests yet, but it got through AM2,super-Pi, & 3dmark `06 at those settings without a problem.
I'm not ready to start playing with the settings yet (don't know a thing about intel platforms after 15+ years of running nothing but AMD), but I'm itching to find out if de-linking the mem (I think thats async vrs sync isn't it?) will leave it exactly at that point.
Old April 18, 2007, 03:43 PM
Babrbarossa's Avatar
Whatcha got in there for a cpu?- did you get the e6420?
Old April 18, 2007, 04:20 PM
sswilson's Avatar
Yep, I got the second one of only two they got in at Mysterbytes (steal @ $296), and so far they're having a problem getting any more. (Release date was supposedly april 22, but I know they've been advertised as "in stock" for a week or two).
The DDR 512 reading was apparently wrong.... I'm using a newer cpu-z version now and it's showing 192, so it's running under DDR400 speeds.
The cpu is also running slightly below stock. It's reading 2050 vice 2130, so that might account for the below ddr400 speeds.
Temps under load are 27 & 25.
This is going to be fun..... been a long time since I had something new to sink my teeth into.... :)
Old April 18, 2007, 04:58 PM
I can't wait to see- what is the stepping- I've been reading over at XS that there's alot of them that won't even go over 3.0- some are doing fine though.
Perhaps Intel has been saving up all of it's 'failed' e6600's, and now is releasing them as 6420 and 6320- I hope not.
Old April 18, 2007, 05:12 PM
sswilson's Avatar
The stepping is (I'm assuming it's the lot#, there wasn't anything written on the HSF that wasn't on the box label) L644G289.
Do you have a link to the discussion about the steppings?
  #19 (permalink)
Old April 18, 2007, 05:23 PM
I saw that one person had a great OC with a wekk 44 stepping (that's what you got.
Here's a couple of releated threads:
New E6600 batches, post your Overclock - XtremeSystems Forums
Newer batches of Conroe OCing poorly? - XtremeSystems Forums
there was another somewhere...
  #20 (permalink)
Old April 18, 2007, 05:32 PM
sswilson's Avatar
Thanks for the links.
I just discovered that I won't be doing any high end OC'ing on this board as it doesn't have any ability to change cpu voltage or multi......
Gonna have to dig around to see if there is a bios mod around somewhere that includes it. (Bummer, as the review I've seen was using an "engineering bios" which included at least the ability to change multies).
That's ok though, I didn't expect too much out of this board as I'll be saving up for a real board after I pick up some DDR2 mem.
Comment thread for the "Asrock 4CoreDual-VSTA" review sswilson CPU's and Motherboards 16 December 18, 2007 09:04 PM
I just dumped by ASRock 4Core DualVSTA KnSKranky CPU's and Motherboards 5 November 14, 2007 01:58 PM
Asrock 4coredual-vsta - blank screen josh_45 Troubleshooting 9 May 19, 2007 10:49 AM
Using AsRock Untied Overclocking with an Intel SP79K ? lamimartin Overclocking, Tweaking and Benchmarking 0 May 4, 2007 08:28 AM
