Old November 26, 2011, 02:20 PM
Blu's Avatar
Blu Blu is offline
Default Need server advice...
I currently usually order this server,
Professional EG Best Of dedicated server - OVH
It's good and can handle 16-20 users pretty decently, but a staff member point this one out.
Professional MG Best Of dedicated server - OVH
I just wanted to know if the first one can handle up to 20 users how many would this one be able to hold? Also which CPU is better? the Top one has hyper threading and the bottom on is just 8 physical cores? So wouldn't that be about the same. Thanks for any help.
Old November 26, 2011, 11:23 PM
Blu's Avatar
Blu Blu is offline
No one has any advice as to what cpu is better?
Old November 26, 2011, 11:42 PM
supaflyx3's Avatar
1st one is better, the xeon your server uses is basically an i7 as it has HT, the second one is basically an i5 and doesn't have HT.
Possible file server/hosting server Mistertuxedopants New Builds 13 September 19, 2011 12:34 PM
Cost Effective Server Back Up solution (Advice Needed) CoolHandL New Builds 4 December 29, 2010 05:37 PM
WIP Home File Server - Modding Rack mount Server Chassis CoolHandL Case Mods, Worklog & Gallery 24 December 22, 2010 12:37 PM
tfc server Haiden New Builds 3 March 27, 2010 09:19 PM
Server Advice Scratch CPU's and Motherboards 4 September 27, 2008 11:34 AM
