Old November 24, 2011, 08:21 AM
Default CPU and GPU temps?!
Hi guys,
I wanna know what temps are save to have for the cpu and gpu
because I am going to overclock them.
and if you wanna know what cpu and gpu I going to buy is
intel i5 2500K
xfx radeon hd 6970
hope you can help me with this
greatings
Old November 24, 2011, 08:36 AM
Soultribunal's Avatar
What case is it all going in and what cooler are you putting on your CPU?
ST
www.realhardwarereviews.com
Old November 24, 2011, 09:53 AM
ST
I know it will be different temps if you have different heatsinks and cases etc.
but I just wanna know what temps are the max for the cpu and gpu :)
Old November 24, 2011, 10:03 AM
SugarJ's Avatar
My "safe" max temps are 70 for Intel CPU's and 85 for GPU's. There's no hard rule for max temps, but the chips will thermal throttle if you get them too hot.
Old November 24, 2011, 02:27 PM
I would try to keep below 70 load temps on the Sandy Bridge chips 2500/2600
For the gpu, the current Radeons are designed to trip at if I recall 120c on the Vregs-115c on the core and shutdown temp of no more then 125c on Vregs area, however it should never get this hot, as likely there is damage done if it stays t this to long "throttling" itself due to overpower(power tune limits) or overtemp"throttling/shutdown)
A safe temp for GPU would be 80 or below, this lets the Vregs/memory hit maybe 90c or so, well within thier "safe zone" I like to see mine hit no more then 74c or so on my 6870 and previously on my 4870, but 6950/6970 do run warmer so add a couple c to this and your at 80 :)
NH-D14 Temps vintank Air Cooling 12 February 15, 2010 06:52 AM
Help with temps! ITaoI CPU's and Motherboards 2 August 16, 2009 05:20 PM
These Temps OK? fuctfuct Air Cooling 6 August 2, 2009 04:11 AM
Are these temps right? overlords Air Cooling 15 January 18, 2009 04:10 PM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
