Hi , Ive been researching for a week now and basically have come up with really mixed up answers and thought you guys might be able to shed some light on this situation.
I Have a Dell xps 700.....yes its old but i believe it still has life in it.(need it to live for 1 more year b4 i buy again ..it was expensive 2700$ in 07)
Not too happy with dell anymore (ill build next time) they had a "60 day motherboard free exchange " from xps 700 to 720 boards that i was never informed about back in 07 .they had this because the 700 didnt have a great upgrade path ! I bought it thinking it did ......Long story short
I need more processing speed . Dell tells me that the highest cpu they can offer me is
* Intel® CoreTM 2 Extreme X6800 (4MB L2 Cache,2.93GHz,1066
which i dont find worth it for this old machine.
So then i read this
Re: XPS 700 Processor Upgrade - Desktop General Hardware Forum - Desktop - Dell Community
And they say i could go for the quad
q6700 -qx6800 found both on ebay for under 200 bucks various sellers..
but Im not really sure about this
same socket same tech Nm same fsb ,
i guess dell wouldnt tell me about it because they want me to buy a new motherboard or even a new pc all together
i just dont want to screw up the pc or waste my money .
Ive tryied overclocking and with the xps 700 your forced to use Ntune with a locked cpu so you need to fsb it and im not sure what the board can take over 1066fsb and dont know how far 800mhz ram can be pushed(i know thats another subject)
should i risk the quad ? Could it screw up my pc?
anyway thanks for your time guys !
Dan.
some various specs below from cpuz
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E6400
Codename Conroe
Specification Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.F.6
Extended CPUID 6.F
Core Stepping B2
Technology 65 nm
Core Speed 1596.0 MHz
Multiplier x FSB 6.0 x 266.0 MHz
Rated Bus speed 1064.0 MHz
Stock frequency 2133 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 8.0x
Max VID 1.325 V
Chipset
Northbridge NVIDIA nForce4 SLI Intel Edition rev. C1
Southbridge NVIDIA nForce 590 SLI rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 8192 MBytes
Channels Dual
Memory Frequency 399.0 MHz (2:3)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 22
DMI BIOS
vendor Dell Inc.
version 1.4.1
date 05/07/2007
Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 2 (Build 6002)
DirectX Version 11.0
1000watt psu
Thanks again for reading !
