Old November 22, 2011, 01:25 PM
Default Why this CPU wont work on my mobo?
Hi
I bought a brand new Intel Pentium Dual Core E5700 3.0ghz to replace my old Intel Pentium Dual Core E2140 1.6ghz, but if I put the E5700, it wont boot, the PC just starts including fans, video card, hard-drive, DVD-RW, but I get yellow led at screen, so the screen is black(system wont boot), but if I put back the old 2140, it works. From what I founded out from Asus site my mobo is compatible with E5700 but only with the BIOS updated to the latest version which I have(0214), so I dont know what might be the problem. I confirm that the CPU is functional, I tested it on my cousin`s pc
HERE MY SPECS IT MIGHT HELP YOU:
power suply: ANS ATX450W P4
mobo: asus p5ld2-x/1333
ram: 2.5gb ddr2
video card: asus nvidia 8500gt 256mb ddr3
hdd: 160gb WD 7200rpm/sata
DVD-RW: Asus DRW-1814 blt
tv tunner: TV-PVR 878
please help me :)
Old November 22, 2011, 01:42 PM
KaptCrunch's Avatar
P5LD2-X/1333
BIOS version: 0212 Support new CPUs. what bios version your at now ?
Old November 22, 2011, 01:43 PM
Originally Posted by KaptCrunch View Post
P5LD2-X/1333
I also said above, 0214
if a man would rule the world and lose his soul.....
Old November 22, 2011, 01:51 PM
sswilson's Avatar
You didn't mention if you did a cmos reset after replacing the cpu... that might do the trick.
Old November 22, 2011, 01:52 PM
i did it, many times actually, it didnt work
Old November 22, 2011, 02:57 PM
You positive the new BIOS took? Sounds 100% like incompatible chip to me. I have had to redo a BIOS update because the flash didn't take and the original one remained. Only happened once to me in the 100 or so boards I've flashed but you never know. Also you might want to pull the battery and leave the CMOS jumper on CLEAR for a half hour or so just to make sure it has cleared completely.
The only things I can think of, very bizarre.
Old November 22, 2011, 03:15 PM
KaptCrunch's Avatar
forgot to read manual. page 6 sec 2.3, its not showing Wolfdale core as supported on ypur MB
Old November 22, 2011, 03:19 PM
Remove the tuner, one stick of ram and make sure you have the CPU power cable attached properly. Sometimes bare minimums helps.
The E5700 is compatible with the 0212 BIOS, straight from Asus website. The manual is probably outdated.
Old November 22, 2011, 03:27 PM
The manual would only have the chips that were supported at the time of the printing and with the original BIOS which did not support the e5700.
Old November 23, 2011, 01:37 AM
so, the motherboard should work with my new cpu, the bios flashed succesfully and I can see in bios version 0214.
I tried everything:
-I removed the tv tuner
-I removed one ram, than the other one, lefting just one I have a 2gb and a 512 one
-I changed the supply
-I tryied with another video card
-I did cmos(by removing battery and with jumper)
-I even tried to flash bios with just the mouse and keyboard and monitor plugged in
but nothing........... :(
Attempt #10 to get work failed, and no other work to do. LaughingCrow HardwareCanucks F@H Team 3 May 5, 2010 08:29 AM
Mobo ethernet port isn't work... =( do I need to RMA? feerof Troubleshooting 10 May 3, 2010 01:39 PM
PC wont work after sleep mode? SadisticMonkey O/S's, Drivers & General Software 21 October 16, 2009 01:12 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
Help games wont start or work well! mailaw Gaming 2 September 2, 2007 05:10 PM
