Old November 23, 2011, 02:44 AM
Originally Posted by Rasparthe View Post
You positive the new BIOS took? Sounds 100% like incompatible chip to me. I have had to redo a BIOS update because the flash didn't take and the original one remained. Only happened once to me in the 100 or so boards I've flashed but you never know. Also you might want to pull the battery and leave the CMOS jumper on CLEAR for a half hour or so just to make sure it has cleared completely.
The only things I can think of, very bizarre.
in bios says that is version 0214
if a man would rule the world and lose his soul.....
Attempt #10 to get work failed, and no other work to do. LaughingCrow HardwareCanucks [email protected] Team 3 May 5, 2010 08:29 AM
Mobo ethernet port isn't work... =( do I need to RMA? feerof Troubleshooting 10 May 3, 2010 01:39 PM
PC wont work after sleep mode? SadisticMonkey O/S's, Drivers & General Software 21 October 16, 2009 01:12 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
Help games wont start or work well! mailaw Gaming 2 September 2, 2007 05:10 PM
