<~----> i7-920 vs i7-965x - Hardware Canucks
Old November 20, 2011, 08:14 PM
Default i7-920 vs i7-965x
is it worth the upgrade? or should i just hold out until someone lets go a 6core
Old November 20, 2011, 08:55 PM
lol
most 965x are c1 and dont overclock too good
get a better heatsink n
just overclock your cpu
you better off with a good 920 D0 than an overated 965
i had 2 975x and my 920 is alot better
the 965x i had sucked
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old November 22, 2011, 11:15 AM
FreeKnight's Avatar
I'd agree. While I usually run my 920 at stock speeds, I've managed stable overclock up to ~4Ghz (I don't remember exactly off the top of my head) with a good cooler.
My System - Mimir
|- Intel i7 920 -| - Corsair 850w HX Modular PSU -|- Gigabyte G1. Sniper -|- 24GB Corsair Vengeance DDR3 -|- Prolimatech Megashadow Cooler -|
- EVGA GTX 670 FTW -|-2x Crucial M4 256GB RAID 0-|- Seagate Barracuda 3TB -|- WD Caviar Green 2TB HDD -|- Corsair 600T White -|- Windows 7 Ultimate -|
Old December 3, 2011, 05:06 PM
somecanadianguy's Avatar
Yeah, I've got a 920 (C0) that is stable at 4.2GHz on air.
I'm happy with it until I can get a 6-core.
Old December 3, 2011, 06:27 PM
Your_friendly_gamer's Avatar
If you are going to be using your rig primarily for gaming then extra 2 hyperthreaded cores will be an over kill for the price. Unless you are going to be folding then yes. I would overclock the **** out of the 920 untill it dies and then get something better, like sandy bridge or something!
