Thank you, Babrbarossa. Pretty darned good answer, I'd say, engineer or not.
Hmmm. . . good enough that I'm now a bit perplexed.
Well, let's see. . . .
My AMD 64 x2 shortlist includes versions with L2 = 1024 x 2, and nothing @ 125 watts. On the low side, that eliminates the Brisbanes (L2 = 512 x 2), and on the high side it eliminates the 6000+ and 6400+ (125 watts).
— AMD 64 x2
5200+ Windsor revF3 EE (Energy Efficient) @
65 watts; core speed
2600
(my choice here is based on maximum power in this series available @ 65 watts)
— AMD 64 x2
5200+ Windsor revF2 @ 89 watts; core speed =
2600 MHz
(seems a waste of power, but if it has better performance, then maybe)
— AMD 64 x2
5600+ Windsor revF3 @ 89 watts; core speed =
2800 MHz
(If I went up to 89 watts anyway, then maybe I'd be better to get this; although I think it might run hotter. I'd like cool as possible, and reasonably energy efficient.)
I want a really steady system that can perform very heavy multitasking without even wincing. I'm pretty close to my preferences on these CPUs, although I'm darned if I know which one I'll choose.
I want a lot of good RAM, probably 8 GB (I'm OK about buying RAM a bit into the future, and my OS will be XP x64 (maybe Vista x64, but I don't like Vista). I'd like an mb that can take even more RAM, as some of the Gigabyte mbs can. Looks like DDR2-800, I suppose.
It's for heavy usage and constant reliability, and I want excellent speed with a ton of photos up to astronomy-size. No gaming, though. I want to avoid heat and I want to keep electrical use low. I'm hoping to add a 22" LCD.
I thought I'd toss that out in case anybody thinks he knows a very nice
motherboard —I'm thinking of maybe a
Gigabyte GA-MA790FX-DS5—
or
video/graphics card.
Or if you have any of those CPUs, it would be great to hear from you.
Thanks again, Babrbarossa.
