Old November 12, 2011, 03:17 PM
Default Is the Core i5 2400 worth it?
I know it can't be overclocked, but if the processor can be obtained cheaply, would it be worth it? What about on a per performance per dollar basis?
Old November 12, 2011, 03:49 PM
Yes it is worth it. Its performance is only marginally slower than a 2500k that everyone wants. Also, it is overclockable, but only by 4 multipliers (400mhz). HWC LINK.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old November 12, 2011, 04:21 PM
4 multi's + FSB for a hundred or so extra
Old November 12, 2011, 04:38 PM
Realistically speaking, how much oc should I be able to get? What will the top speed be?
Old November 12, 2011, 07:29 PM
I'm interested in this chip as well. Right now at ME its $170, compare to ~$220 of the 2500K, which is pretty good for me. Would you say that the higher clock (oc) of the K warrant its higher price? (the difference can be put into a better graphic card for example)
E4500, 2GB DDR2-800, Coolermaster 500W PSU.
Old November 12, 2011, 09:07 PM
if you do folding or very cpu intensive tasks the unlocked processors usually can hit 4.4-4.5ghz but if you're not a number cruncher or editor you'll see no real world gain.
Old November 13, 2011, 04:47 AM
For gaming purpose, you'll not see the difference between the two cpus. And as stated in other posts, the overclocking is good only when it makes a difference in task you do regularly. Other than that, it is just wasted energy. So i really think that 50$ more in your gpu (or in a ssd) will have more impact in your day-to-day computing than going from 2400 to 2500k. That's only my two cents.
Old November 13, 2011, 06:46 AM
The HWC link I posted above they were able to get 4028mhz when only a single thread is running and 3816mhz on all cores as a max OC.
Old November 13, 2011, 08:18 AM
not worth it
you better off gettin the 2500k
you think running @ 106blk the board gonna be happy? 24/7
i went upto 108 blk while playin but no way i goin over 102 blk for 24/7 if i dont need to
and i keep my 2600k @ 100blk x50 24/7 wastin all that electricity lol
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Intel Core i3-2120 & Core i5-2400 Processors Review Comment Thread SKYMTL CPU's and Motherboards 9 July 19, 2011 07:17 AM
How much is my stuff worth Core Unlocked Phenom 2 X2 Setup? kingnubian Off Topic 2 April 5, 2010 03:51 AM
Is it worth the trouble for stepping up EVGA GTX 260 Core 216SC to GTX 285? appplejack Video Cards 4 February 14, 2009 04:05 PM
core 2 to i7 is it worth the upgrade? magictorch CPU's and Motherboards 25 December 3, 2008 08:28 PM
