idle temps on a x6 1055t
i justed got a coolermaster 612 PWM and i was wondering if anyone knows the idle temps for a x6 1055t with a cm 612.
with amd overdrive im geting 34C and with HW monitor its 22C. room temp is around 20C. im guessing amd overdrive is correct.
im also runing dual 5850s and there at 52C and 45C.
case: cm 692 with 6 fans not including cpu fan. 2 front intakes(14cm and 12cm), 2 top outtakes(both 14cm), 1 12cm rear outtake and 1 14cm side intake blowing on the graphics card.
thanks
