Old November 3, 2011, 05:48 AM
Default i7 2600K or i5 2500k?
Hi,
I have today a i7 2600k mounted in my computer(8GB ram, GTX570 OC) and it works great in Battlefield3. Some friends have however said that I should switch to the i5 2500k and get 73,65 EUR back? This is no performance loss what so ever between i5 2600 and the i7 2600 in games?
Is this true? And is there anything in the future that sugest that I should stick with the i7?
Old November 3, 2011, 06:07 AM
supaflyx3's Avatar
You will see very minimal difference while gaming in BF3, i would suggest going for the 2500K if you don't do any major multi threaded rendering (IE editing video, pictures etc)
Old November 3, 2011, 06:10 AM
Arinoth's Avatar
For games, you won't notice a performance difference really as most games use at most 4 cores (and i think that's only BF3). Most 1-2, meaning having 8 (4 physical + 4 from hyperthreading) won't make a difference as they aren't/won't be used at all. The added threads are mainly for programs that use a lot at once, for instance Fold@home, or say handbrake.
Here I am: here I remain
Old November 3, 2011, 06:42 AM
Thanks!
But If we take a look at a test like this :
Intel Sandy Bridge: Core i7 2600K, Core*i5*2500K - Test / Recension - Processorer - SweClockers.com
Its in swedish but just look at the graphs (green=average red=minimum)
When running the game in 1280x1024 Medium we can see that the CPU does make diffrence(33 fps). When running at 1920x1200 High we can see that there is no diffrece and this is probably due to the limit of the GPU.
So If we think that we will have this CPU a long time and switch at least 2-3 graphic cards before the CPU is to be upgraded. Then we would probably come to a point where the CPU will be the limit and with a i7 we will get alot more fps from then the i5.
Is this wrong thinkin?
Old November 3, 2011, 06:45 AM
supaflyx3's Avatar
Games won't utilize more then 4 cores properly for quite some time, And even at that point when the CPU starts to become a bottleneck with the right cooling you should be able to reach 4.5Ghz or even 5 to overcome that bottleneck.
Old November 3, 2011, 06:48 AM
Arinoth's Avatar
If you're playing at that low of a resolution you are essentially shifting a lot of the load to the cpu rather then the graphics cards. At a standard gaming resolution (i'd consider 1080p the standard now). You can see it makes no difference whatso ever really. This is going to be the trend for a while until we get more games moving towards better/more multithreading (which if we look at the market now is going to be a long while).
Old November 6, 2011, 06:15 PM
Seconded. I do a lot of video editing and 3D modeling - the 2600k made more sense, at least for me...
Old November 6, 2011, 06:40 PM
Default RE: i7 vs i5.....
+1 for the i7!!!!!!
Balls
Grow Dem!!
JP
Old November 7, 2011, 10:15 PM
im leaning towards the 2500k....
Old November 7, 2011, 11:25 PM
If you don't already have a system built with an i7, and gaming is your primary usage, 2500K is the way to go.
2600K @4.6
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
Gigabyte GTX780
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
[WTB] Intel 2500k/2600k richuwo11 Buy/Sell & Trade 1 September 30, 2011 08:58 AM
[WTB] WTB 2600k or 2500k, also a s775 mobo Table21 Buy/Sell & Trade 2 September 2, 2011 07:42 PM
i7 2600K vs i5 2500K (Almost built) sstrucel New Builds 9 August 17, 2011 09:48 AM
2500k or 2600k kyle_L New Builds 4 August 4, 2011 10:49 AM
Having Core i5 NON K Hould I buy a 2500K or a 2600K hellire666 CPU's and Motherboards 10 May 16, 2011 04:23 PM
