Old November 2, 2011, 05:56 PM
Default cpu choice?
hey guys,
im currently pricing up a system for gaes and other school work and was wondering if i should go for a amd x4 965 for $139 or the x6 1090 t for $189 and will both these processers run of a 4 pin cpu power ?
thanks guys
Old November 2, 2011, 08:10 PM
Soullessone21's Avatar
what mobo you got there home slice?
I can tell you what will work and offer you suggestions. I am a Asus Tech who works on the AMD side of our fine company.
Old November 3, 2011, 02:03 AM
hey mate well i got an old motherboared and both cpu's work on this boared with a simple bios update which i have just done its a askrock boared micro atx and i was wondering wat would be the best cmbinations with a gtx 560 ti twin frozr.?
SSD choice homer98 Storage 4 November 9, 2010 05:02 AM
If you had the choice.. _dangtx_ Off Topic 11 September 4, 2010 02:31 AM
Which one is a better choice? BootlegUsher Power Supplies 4 December 21, 2009 02:04 PM
Need some help on this choice monkey_mo CPU's and Motherboards 3 June 27, 2009 06:54 PM
RAM choice 486 RAM 13 February 12, 2009 11:08 PM
