Old October 22, 2011, 09:36 PM
BVickery's Avatar
Default Next Gen Ivy Bridge
Ok, there appears to be a new Ivy Bridge slated for release early as March (pretty much die shrink to 22nm). They are also going for a new chipset, so you think a new socket will be forthcoming? I am looking to upgrade to possibly Ivy Bridge in around Jan/Feb and wonder if it would just be worth it to wait for the next generation and keep saving and get bit more than I was originally going to get.
Old October 22, 2011, 09:50 PM
lowfat's Avatar
Besides LGA2011, no new sockets on the horizon for quite some time. LGA1155 should be the mainstream socket for a few more years at least.
Mael
Big Lian Li
Forever Alone
Old October 22, 2011, 11:20 PM
BVickery's Avatar
thanks.
Old October 23, 2011, 08:25 AM
Keep in mind that not changing the old socket doesn't mean you'll have backwards / forwards compatibility (as usual).
AnandTech - Intel's Ivy Bridge Architecture Exposed
You'll need a BIOS update to get a current 1155 board to work with IVB, and the new boards won't work with SNB unless AsRock does the same trick like it did for is "P67 Transformer" board.
Old October 25, 2011, 08:03 AM
yycraven's Avatar
Was reading this morning,
http://www.fudzilla.com/processors/i...mes-in-q3-2012
EK FC bridge for SLI magictorch Water Cooling 3 January 24, 2011 10:24 AM
Where to get a sli bridge? Modus Video Cards 7 September 29, 2010 09:37 PM
Older SLI Bridge O.K? Slik Video Cards 10 September 20, 2010 09:35 AM
Crossfire Bridge? Slik Video Cards 4 June 3, 2010 04:55 AM
[WTB] SLI Bridge CMetaphor Buy/Sell & Trade 12 September 8, 2009 05:15 AM
