Old February 23, 2008, 03:17 PM
Trial Member
Default e8400 Compatable Motherboards
I'm looking to buy an E8400 and new motherboard. I've heard that a lot of the motherboards require you to update the BIOS with an older socket 775 processor before it will recognize the new E8400. I don't have a socket 775 cpu kicking around so I wouldn't be able to flash it.
Anyone know of any boards that work with the E8400 right out of the box?
Thanks.
Old February 23, 2008, 03:26 PM
3.0charlie's Avatar
A member here has an E8400 for sale; check out the FT/FS section. As for a board, most P35s and X38s can work with an E8400. Which ones? It depends what is your preference.
And welcome to the forums.
Hydro-Quebec is salivating...
Old February 23, 2008, 04:30 PM
1Tanker's Avatar
Thanks.
My E8400 worked on my GA-P35-DS3L(rev. 2.0) right out of the box.. and she's only $90. GL
Old February 23, 2008, 05:04 PM
Until my understanding, the e8400 should work with most x38, p35 and 680i chipset boards, it just needs a bios update before you put the processor in..
Old February 23, 2008, 05:37 PM
omgwtf's Avatar
So you need another processor whom you can update the mobos bios version...
Memento mori
Old February 23, 2008, 07:43 PM
most of us are probably gonna be upgrading to a newer cpu so like an example if I buy a e8400, currently I have a e6600 in use, I use that to flash the bios to a newer version (most manufacturers have a bios to support the new 45nm chips) and then install your e8400 so it works out of the box..
Hope you get it..
Old February 23, 2008, 07:50 PM
Hmmm, so what about those of us upgrading from an older CPU. Myself I will be going from an slot 939, so simply using my existing processor is not an option.
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old February 23, 2008, 07:55 PM
omgwtf's Avatar
miggs78 I knew that, just saying it for whoever doesn't know it..I think you interpreted that as a question
CasheKicker: you can't use an amd cpu on a intel mobo ...that's logic
Memento mori
Old February 23, 2008, 07:57 PM
magictorch's Avatar
i think i read somewhere that the current asus p5K-E will post you into bios-- at least then you can flash with a usb stick with the bios downloaded fromt he asus site on another system.
Old February 23, 2008, 08:32 PM
b1lk1's Avatar
ASUS P5N-D. It uses the 750i chipset and should be a reasonable overclocker. I just put mine in but I am waiting for zlojack's E8400. Should be running by mid week. This board takes E8x00 out of the box too.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
QX6850 - Recommended Motherboards and Memory ElectricWag CPU's and Motherboards 1 December 1, 2007 02:23 PM
790FX motherboards revealed! Zertz Rumor Mill 7 November 9, 2007 05:19 PM
AM2+ motherboards? sswilson CPU's and Motherboards 7 August 21, 2007 12:17 PM
TweakTown on Intel P35 motherboards—five in the pit Supergrover Reviews & Articles from the Web 0 August 12, 2007 11:17 AM
Eight P35-DDR2 Motherboards Compared Babrbarossa Reviews & Articles from the Web 4 June 20, 2007 04:43 PM
