  #231 (permalink)
Old December 2, 2011, 10:35 AM
Shadowmeph's Avatar
has anyone tried to fold with one of these yet?
  #232 (permalink)
Old December 8, 2011, 09:39 PM
Trial Member
Default Comparison
I dunno if anyone noticed, but if u study the architectures carefully, then what AMD calls as a 'module' is comparable to a 'core' of Intels. Intels Hyperthreading allows two logical thread executions per core. But AMD's TruCore theory, only allows one thread per core. The Intel i5-2500K has 4 physical cores and 8 logical threads. Compared to that the most powerful of the AMD, the FX-8170, contains 4 modules which can execute 8 threads, with 2 cores per module, each core executing 1 thread. On the other hand the i7-2600K contains 6 physical cores and 12 logical threads. Hence by no chance, can the FX-8150, can match the capability of the 2600K, as the latter as 2 more cores to add to the power. As for the results of the benchmarking, it also agrees with the fact that the FX-8150 is comparable albeit a little less powerful than the i5-2500K, because of the architecture difference between Intels core and AMD's Bulldozer.If AMD ever brings out (according to them) a 12 core FX processor (Prob. FX-12XXX), then it would be really interesting to see how that matches with the i7-2600K. Altough the shared L2 cache architecture, is what may be detrimental to the performance of these processors. But frankly I am overall disappointed with the performance. I made a AMD rig this October with a 990FX board for upgradation to teh bulldozer. Now I think I'll hold onto my Phenom II x6 until, Piledriver shows some radical improvements, that is even if AMD bring out Piledriver to the AM3+ socket.
  #233 (permalink)
Old December 8, 2011, 10:37 PM
Supergrover's Avatar
i7 2600/k are 4 core 8 threads via HT, i72500/k are 4 core 4 thread no HT.
R.I.P.
  #234 (permalink)
Old December 8, 2011, 11:06 PM
great_big_abyss's Avatar
Ya, the 2600/2700s are quad cores with hyperthreading.
Anyways, I don't think it's a question of raw power. I think the biggest disappointment about Bulldozer was the fact that performance wasn't as good as the new Intel chips, but the power consumption was exceedingly high. If the chips consumed a lot less power and were therefore more efficient, I don't think they would be considered such a fail.
  #235 (permalink)
Old December 8, 2011, 11:34 PM
Galcobar's Avatar
i7-2600K has Hyperthreading, i5-2500K does not.
The short form is that for the desktop second generation Core processors, i3 is two cores with HT (four threads), i5 is four cores with Turbo Boost (four threads + Turbo), i7 is four cores with Turbo and HT (eight threads + Turbo).
Only problem is that Intel doesn't follow any sort of strict rule in regards to what feature differentiates between i3 and i5 and i7, just that there will be a feature difference. As a result, you can have a processor be i5, but have Turbo and HT, as long as it only has two cores. There's only one such second generation desktop i5, and it's a low-temp (T) variant.
And then you get into laptops, where the i3 is two core/four thread, the i5 are two core/four thread with Turbo, and the i7 can be two core/four thread with Turbo or four core/eight thread with Turbo and may or may not have integrated graphics.
Though I've also noticed that Intel's own charts aren't always the most accurate when it comes to processor features. The summary currently lists the i7-2700K as having no IGP, for instance, though the individual processor page is correct.
  #236 (permalink)
Old December 12, 2011, 09:15 AM
Well, the inherant problem is peaple dont think about the 8120's in the 125 & 95w range so they just string them ALL up as burning power period ... BUT if ya go look at windwithme's posting of the 95w 8120 AMD’s newest Bulldozer architecture – FX-8120 8Cores performance and OC 5G ... stock settings the standby/idle's 74 watts & load/full speed 157 on LinX. Thats with a biostar 990fx board & a 560.
  #237 (permalink)
Old December 12, 2011, 09:44 AM
On a slightly different note, a friend of mine ordered an 8150 for his server. Rather, he PRE-ordered it before they went on sale. Initially they promised that he would get it mid-november, but at this point he still hasn't seen hide nor hair of it. Something seems to be broken in their distribution lines.
  #238 (permalink)
Old December 12, 2011, 09:49 AM
geokilla's Avatar
Where'd he buy it from? Time to cancel order?
  #239 (permalink)
Old December 12, 2011, 09:51 AM
He's a reseller, so he ordered it directly from one of his distributors. It seems like all the initial 8150's were sold to large companies, and all the little guys were left out in the cold.
Edit#1: I cancelled my order a month ago. It would have been okay if I had received it, but the longer I waited, the longer i started to wonder if it was really worth it. Turns out I'm glad I cancelled. I'll wait and see what Piledriver is like, and if it's compatible with AM3+
Edit#2: If Piledriver isn't as good as I want it to be, I suppose it will be time to ditch AMD (who I have supported since I built my first computer 10 years ago) and move over to Intel. I'll wait until my current CPU can't handle the latest games then make the move.
  #240 (permalink)
Old December 12, 2011, 10:02 AM
Soultribunal's Avatar
My cousin and I both have supported AMD for the longest time and had systems prepped to take the new AMD chips.
But when our Thubans are doing just as good for the most part or a few points lower Clock for clock whats the point right? I'm with you on teh support side though. I remember my thunderbird very well.
Its a shame really, hopefully sometime in the future they will have good direction again as well as performance.
ST
www.realhardwarereviews.com
AMD Phenom II X4 980 Black Edition Processor Review Comment Thread SKYMTL CPU's and Motherboards 12 May 3, 2011 06:27 PM
Intel Core i7-980X Gulftown Processor Review Comment Thread SKYMTL CPU's and Motherboards 103 September 23, 2010 01:21 PM
BFG GTX 260 Review Comment Thread SKYMTL Video Cards 33 November 15, 2008 11:26 PM
BFG GTX 280 OCX Review Comment Thread SKYMTL Video Cards 15 August 19, 2008 08:07 PM
