Old October 10, 2011, 12:21 PM
Default HELP!! I Need somebody!
Does anyone know of a motherboard that can support SLi on AM3+ with hdmi onboard. HELP
Old October 10, 2011, 12:26 PM
Pretty sure AMD boards don't support SLI. Someone correct me if I'm wrong though.
Old October 10, 2011, 12:28 PM
Your wrong
Old October 10, 2011, 12:29 PM
geokilla's Avatar
How do you know he's wrong? If you know he's wrong, then you know the answer to your question already.
I'm pretty sure I've seen some AM3 SLI motherboards before.
Old October 10, 2011, 12:59 PM
lol ya if you already know he's wrong...
it USED to be that amd boards did not support SLI
i believe the new chipset design works with SLI now though
just have to check the specs on motherboards
Old October 10, 2011, 01:03 PM
supaflyx3's Avatar
Almost all AM3+ boards support SLI, and any nvidia chipset amd boards do as well.
That being said, just look at 990fx boards and try to find one that has hdmi out, but why do you need onboard hdmi? if you're going to be running sli..
Old October 10, 2011, 02:33 PM
norfolk's Avatar
This seems to be the best bang for the buck board
Canada Computers | Motherboards | Asus Sabertooth 990FX Socket AM3+ AMD990FX/SB950 Chipset Dual Channel DDR3 2000(O.C.)/1866/1800/1600/1333/1066 MHz 4x PCI Express 2.0 x16 Slots 8-Channel HD Audio GigaLAN 6x SATA 6Gb/s+2x SATA 3Gb/s 4x USB 3.0 ATX
I have the R.O.G. Crosshair V but they are a little buggie and a pain to get set up,
The Sabertooth is the way to go.
Old October 10, 2011, 02:46 PM
norfolk's Avatar
Yeh it seems a little pointless.
Old October 10, 2011, 04:34 PM
Shadowmeph's Avatar
I have not heard of any motherboards that have HDMI output onboard.
Old October 10, 2011, 04:42 PM
MARSTG's Avatar
if we are talking about the AMD series 9 chipset family, there is nothing with onboard video like the 880G/GX. The chipset versions are only 970, 990X and 990FX. No onboard video for AM3+ series 9 chipset.
