-   -   CPU Fan header question (http://www.hardwarecanucks.com/forum/cpus-motherboards/47105-cpu-fan-header-question.html)
Pabz0r545 October 7, 2011 04:53 PM
Is it safe to plug a 3 pin CPU fan header into a 4 pin CPU fan header on my mobo? I am re building my old computer and I purchased an aftermarket heatsink but it only has a 3 pin header on it, and the mobo only has a 4 pin header.
Thanks.
Arinoth October 7, 2011 04:57 PM
Yep, that fourth pin is actually the PWM (Pulse-Width Modulation) wire, essentially it allows the computer to control how fast the fan speed is without altering the amount of voltage delivered to it. 3 pin fans can only have their fan speeds changed by changing the voltage delivered to it.
Pabz0r545 October 7, 2011 05:08 PM
Thanks for the swift reply! :)
Is it safe to assume that the CPU fan will run at full speed automatically in this case?
Arinoth October 7, 2011 05:12 PM
Yep, that's a correct assumption.
Pabz0r545 October 8, 2011 12:39 AM
Ok to make a long story short, when I got all my parts for my new computer I dis assembled my old pc to give it a good dust with can of air and a cleaning. I then set it back up and tried to post and got the message:
"Error: The System Fan Has Failed!Service PC to prevent damage to the system.
Press <F2> to Continue"
So I ordered a new CPU heatsink/fan thinking the fan had crapped out on the old heatsink. It arrived today and I installed it. Set up the mobo, ram, GPU, and PSU to see if the system would post and I am getting the same message. I read a few solutions online but they require going into the bios and I just can't seem to get in. I tried spamming del, f1, f2, f10, f11 and insert. None of them will get me into the bios. The motherboard is an HP/Asus IPIBL-LA if it helps at all. None of the parts have changed except the heatsink and the ccomputer was working perfectly fine before I decided to clean it up.
If I press f2 it proceeds to ask me to insert a boot disk or boot drive/media(sorry can't remember this exact message). And to press ctrl alt del to reboot.
I'm a total noob, and I have no clue what to do. Anyone have any suggestions?
ilya October 8, 2011 01:19 AM
Disable fan failure warnings in BIOS.
Pabz0r545 October 8, 2011 02:02 AM
I'm such a noob. The warning wasn't even about the CPU fan it was about the case fan that plugs into the mobo. It was unplugged so I was getting that error code. OMG I didn't even need a new heatsink. :doh:
DOH
uwish October 8, 2011 04:29 PM
:haha: it happens
