Old October 5, 2011, 04:57 AM
Trial Member
Default I need to choose a 1155 motherboard for my first system build
I am a first-time system builder and I cannot decide which mobo to chose. I would like USB 3.0 and Sata III as well. I am planning on using a GTX 560 directcuII and an i5-2500k. My price range is up to 150, which is 240 $canadian. I would prefer a z68 chipset, but as I am a noob, I may not make the right decisions.
Please can you help me out?
Old October 5, 2011, 12:27 PM
Hi, I am a first time system builder just having built my first system recently as well. I am not sure if you need a Z68 and to be honest I am not even sure of the differences between z68 and p67( I think it's the smart response technology and SSD caching? IDK). I decided to go with the p67 myself. Anyways here are a few of the boards you might want to chose from in z68. Most manufacturers have a similar board in p67.
GIGABYTE GA-Z68XP-UD4 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
ASRock Z68 EXTREME4 GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
ASUS P8Z68-V PRO LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
If you look into the P67 and find it will suit your needs fine you might be able to save a few bucks.
You can use the comparison tool on newegg and be sure to read lots of reviews!
Hope this helps!
Old October 5, 2011, 04:48 PM
gingerbee's Avatar
genez and done love all my gene boards and i owned almost all of them i have a sabertooth adn i like my genez much better
NCIX.com - Buy ASUS Maximus IV GENE-Z Z68 LGA1155 mATX 2PCI-E16 1PCI-E4 SLI CrossFire HDMI USB3.0 SATA3 Motherboard - ASUS - MAXIMUS IV GENE-Z - in Canada
Old October 5, 2011, 07:55 PM
If you plan on doing any overclocking (you have a 'K' chip listed, so one would assume so), I would stay away from Gigabyte right now - their voltage options and settings are a MESS right now, as I found out after I bought one. My last 2 high end boards have been giga, I have had excellent luck with them and so have no long term bone to pick, but I'm not very happy with this one.
I'd recommend ASUS.
2600K @4.6
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
Gigabyte GTX780
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old October 5, 2011, 09:59 PM
aristhrottle's Avatar
I'm very happy with my ASUS P8Z68-V PRO. The UEFI BIOS is very nicely laid out and it was easy for me, a relative novice, to achieve a decent overclock.
"CFL receiver Sylvain Girard announced his retirement today. His party will be held at The Keg, right after he and some other players finish their shifts there." - Air Farce
Old October 5, 2011, 10:05 PM
yes gene-z one of the best you can buy after his big brother the extreme-z
i got a sabertooth too
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Will an i3 1155 work in a 1366 motherboard? Other options? Theolonious New Builds 10 August 27, 2011 06:05 PM
Cheap 1155 Gaming Build wesamess New Builds 9 August 7, 2011 07:21 PM
Recommend a 1155 motherboard MrDiaz CPU's and Motherboards 14 July 18, 2011 03:43 PM
Need help to choose a 2.1 audio system. Alpine Audio 9 March 16, 2011 08:31 AM
Help me choose new motherboard (mATX) Cowboy CPU's and Motherboards 5 September 19, 2009 09:00 PM
