Originally Posted by Sagath Have you checked Task Manager to make sure it is BC2 that is utilizing all of the 92%? Or how are you seeing this?
I have a i7 920, and I dont ever remember it utilizing this much horse power. There is definitely something else going on here, and its not your 2500k bottlenecking the 580. |
Without BC2 running, system just idles perfectly at 0 - 2% cpu usage in task manager
As soon as you get in game in sits at 90% usage, I've read many others say they sit around the same amount as well but I just found it hard to believe since the i5 750 didn't utilize this much CPU
I mean the frames are awesome and max load game temps are at 60' so everything is perfect except for me understanding why it is using so much CPU when the slower quad core didnt use as much??
And thanks for replying btw
