<~----> New Build - Advice Welcome - Hardware Canucks
Old February 17, 2008, 08:50 PM
Exclamation New Build - Advice Welcome
Hi All,
Well the time has come to give my 3500+ system to my daughter and start on a new build for my self. I want to make a great system for gaming as well as give my self lots of room to LEARN how to over clock. I have most of my System picked out but I am down to a few choices that make the difference.
The biggest choice is going to be SLI or Crossfire
So this is what I have so far.
CPU - E8400
RAM - Crucial Ballistic 1065 , 2G Kit PC-8500
or - OCZ Reaper HPC 1065, 2G Kit PC-8500
MOBO - SLI Set up - ASUS P5N-D NF750I SLI
- XFire Set up - ASUS P5E IX38
HDD - WD RAPTOR 150G & WD Caviar 250G (already have the drives)
PCU - OCZ Gamer Xtream 850W (alredy have)
GPU - ATI HD 3870
or - EN-8800GT 512m
Antec 900 Gaming Case (Already have)
Cooling ? Freezer Pro7 or OCZ Vidicator 120mm
So when it comes right down to it am I better off with SLI or XFire setup
It my RAM choices the best? Which is better OCZ or Crucial?
Are my Mobo's the best overclocking picks depending on which setup I go with.
HELP. I can not make my final choices. I have never really overclocked before but feel I want to dabble and learn. I am sure I will have lots to learn in that department.
Old February 17, 2008, 08:52 PM
Originally Posted by CasheKicker View Post
Hi All,
CPU - E8400
GPU - ATI HD 3870
or - EN-8800GT 512m
1) Don't bother with SLI
2) Crucial over Reaper
3) Noctua over Pro7 or Vindicator
4) IP35 Pro, P5K-E or Gigabyte board
Old February 17, 2008, 09:05 PM
JD JD is offline
The ASUS P5E is based on the Maximus Formula (which I have) and it's the best motherboard I've had. So the P5E should be of similar quality/performance. If you plan to run 4x1GB of 1066 RAM though, that may be an issue as I see many people have issues with 4 sticks of Crucial on the Maximus.
Cooling, the ThermalRight Ultra 120 eXtreme with a Noctua NF-P12 (or 2 of them) is what I'd recommend. Although the Noctua NH-U12P would also be decent.
I believe the 8800GT is faster than the HD3870, but I'd get the 8800GT from EVGA or XFX myself as they have better warranty than ASUS.
I wouldn't bother with SLI or Crossfire, I've never used it even though my past 3 motherboards have had SLI support. And now my Maximus has Crossfire support which I doubt I'll use. Unless you have a 30" LCD or something where your running a high resolution.
Old February 17, 2008, 09:07 PM
So you would put the 3870 over the 8800GT?
I have been leaning that way myself, but could you please expand? The reviews has the 8800gt winning hands down in most places for gaming.
Old February 17, 2008, 09:12 PM
Sorry should have mentioned my Display. Currently 1 x Samsung 226BW 22" LCD and a 17"CRT but will be getting a second 226BW to keep my other one company. I love running dual display.
If not going Xfire or SLI should I look at steaping up to a 3870x2 or 8800 GTx , possibly wait until the 9800 comes out?
Old February 18, 2008, 12:34 PM
Below_Cost's Avatar
I have been extremely impressed with the Thermalright Ultra 120 Extreme. Absolutely one of the best purchases I have made in in a while.
Old February 18, 2008, 12:47 PM
OK so I will revisit my Heat Sink for sure. The Thermalright 120 extreme looks promising by far. There is one other I readt to day on the Frostytech site that has 1st place to date for best cooling. The name slips me and the site appears to be down at the moment. I will post the other choice when I find it again.
Old February 18, 2008, 02:39 PM
magictorch's Avatar
If you were thinking of SLI- I would put the money into a new 9800GTX which are supposed to be out in the next couple of months. Or I would go for the G92 GTS. I think its worth the extra dollars for that bit of extra power.
BTW did you see that the 4gb Mushkin Redline is only around $160 too (NCIX or DC).
I'm a bit "paranoid" about the P35's compatibility with the new 45nm desktop quads. The boards suggested are great- but this could prove to be a deal breaker. I have no evidence that Intel will make the chips incompatible but its just one of those feelings. Besides it makes for a great marketing pitch for their latest X48 due out at the same time!
Old March 1, 2008, 06:31 AM
Man it is hard to make choices. I now have bought a E8400, soon to be in hand, next step is the mother board.
I am leaning towards SLI setup but can still be swayed the other way into a crossfire setup.
In any case I am beating my head on my desk trying to decide o a board. Everytime I think I have made up my mind I learn something else I want on the board.
So what I THINK I need is the following:
A Mainboard that supports the 45nm core both dual and quad (future upgrade to a quad), Raid suport, 1333 FSB, min 2xPCIe @ 16x TRUE SLI, 4 x DDR @min 1066.
of course the same details in a crossfire board would be acceptable.
Any one have anything to add, even more important a good OCing board that can do all this?
Yes but I am looking to go 1066 and that price is only on the 800
P.S. - Yes SSWilson I am taking all your advise into consideration as well. Don't stop you have been a great help thus far.
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old March 1, 2008, 07:03 AM
b1lk1's Avatar
SLI won't run 2 monitors. You have to disable SLI for that to work. If you have to have dual displays, the 3870X2 or the 8800GTX 768MB are your only 2 choices.
MY HEATWARE
New Build - Could use some advice nophen CPU's and Motherboards 23 March 14, 2008 07:47 PM
New Build Advice Towndrunk CPU's and Motherboards 5 March 12, 2008 10:28 PM
Mobo advice for new build D1rtyB1rd CPU's and Motherboards 26 March 6, 2008 01:23 PM
My Build: Any helpful advice? tgraszat14 CPU's and Motherboards 8 March 3, 2008 08:10 PM
New Build- need advice, opinion Etc UberMoo Off Topic 1 December 17, 2007 09:20 AM
