Old February 17, 2008, 04:13 PM
Default Amd Phenom we're losing 10%to 20% power
I've known about this for some time now thats why when I needed a new processor and I'm a devout AMD fan I went out and bought a Athlon 64 x2 6400+ rather than buy a Phenom or any Quad from AMD. I still can't figure out why nobody knows anything about this TLB errata problem with AMD's Quad cores and how everybody is losing approximately 10% to 20% of the total processor power when they patch each and every one of them. Here's a site that explains it alright, The Tech Report, article Phenom TLB patch benchmarked. Apparantly the Phenom 9600 when patched is approx. equal to my Athlon 64 x2 6400+ so if I were you and was thinking about buying an Opteron or a Phenom Quad I would put it off at least until Stepping B3 is out. Don't take me to my word, check it out yourself.
AMD Phenom ll 955 BE
Gigabyte 890GPA-UD3H
G.Skill Ripjaw X F3-12800CL9D-4GBXL
Tagan BZ Series 800W Power Supply
WD Cavier SE16 500Gb X2 in Raid 0
Diamond Radeon HD 6970 880MHZ
Old February 17, 2008, 04:19 PM
MpG's Avatar
MpG MpG is offline
The TLB errata is fairly well documented at this point. And you can disable the fix with little risk, as long as you're not using virtualization software. B3 steppings are presently expected in a few months. Subject to change, of course.
Old February 17, 2008, 05:50 PM
Mr. Friendly's Avatar
as an added thought to consider...an X2 won't have the multi-threading capabilities of a Phenom. 4 cores is superior to 2 cores, even if they're only performing at the X2's level.
Old February 18, 2008, 02:41 PM
Default Make a very good point
Well now I wish I would have talked to a few more people before I went out and purchased an x2 processor when I could have had a Quad which would have been a lot better than what I have and a heck of a lot better than what they're saying in them articles I read. Maybe I'll sell this on eBay since I have the Asus M3A32-MVP Deluxe WIFI-Ap mobo which is made for Quad core anyway. Anyone know of someone who would like to buy a slightly used Athlon 64 x2 6400+ Am2
Old February 19, 2008, 07:00 AM
Phenom 9500@ 2772MHz
TLB Fix Disabled
Asus M3A32-MVP DELUXE
Diamond ATI 3850's Crossfire
OCZ DDR2 PC2-5400 AM2 Special High Density Kit
or
Crucial Ballistix PC8500 DDR2 1066
OCZ GameXstream 600W
Win XP 32bit
CPU-Z Validator 2.1
This is my sig from another forum, I disabled the TLB patch and haven't had any problems
On this board it's called CPU Tweak just disable it
Old February 19, 2008, 09:17 AM
Rapid-X's Avatar
Default how much
im interested go on how much??
AMD delays Phenom 2.4 GHz due to TLB errata 1Tanker Rumor Mill 8 November 19, 2007 05:59 AM
AMD Phenom CDN $ prices qwerty Rumor Mill 2 November 14, 2007 05:15 PM
AMD's Phenom: Anandtech Babrbarossa Press Releases & Tech News 8 May 14, 2007 08:15 AM
AMD prepares its Phenom FX, Phenom X4 and Phenom X2 lineups Babrbarossa Press Releases & Tech News 1 May 4, 2007 07:38 AM
