Old September 6, 2011, 03:45 PM
lowfat's Avatar
Default Increase DRAM clock, huge increase in CPU temps?
When I generally overclock I find the max CPU clock, then raise my memory clock so rule it out as the cause of a lockup.
Was testing w/ memory @ 400MHz yesterday and I could have sworn CPU temps never went above 62C while @ 4.9GHz. Raise it to 667MHz today and temps are now hovering around 71C. There is no way my ambient temp has increased that much as it really isn't any hotter outside today.
So is this something that is true or no?
Old September 6, 2011, 03:55 PM
I'd say perhaps your memory is dumping more heat near the cpu?
Old September 6, 2011, 03:58 PM
It's possible, but a 9c difference is pretty dramatic, something else must be in play. Did you check your memory controller voltage wasn't on auto? (I'm assuming it's a 2600k)
Old September 6, 2011, 04:04 PM
lowfat's Avatar
I actually lowered the memory voltage by .07V. So it should be putting out less heat.
Pretty sure it is on auto actually. I don't think I've ever actually touched it before.
Old September 6, 2011, 04:27 PM
i cant see memory dumping anywhere near the amount of heat required for that kind of temp rise
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old September 6, 2011, 05:50 PM
Galcobar's Avatar
Chain effect? Memory produces more heat -- faster means hotter, so your voltage reduction might not have had enough effect -- and affects the efficiency of the VRMs nearby?
Old September 6, 2011, 06:19 PM
chek if your pwm getting hot
hotter it gets less stable voltage goes to cpu
it can be crappy memory controler
with my 2600k the higher i go the better temps get lol
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old September 6, 2011, 08:42 PM
lowfat's Avatar
Forgot to mention the CPU is watercooled. Memory or VRM temps shouldn't have much of an impact on CPU temps in my case.
Old September 6, 2011, 08:55 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
It is the IMC which is putting out more heat. You have to remember that while the CPU cores downclock when at idle, the memory runs at full speed.
Old September 7, 2011, 08:38 AM
Default Dynamic power is proportional to clock frequency
Yes, with the memory controller integrated, there will be more heat generated. Remember, dynamic power is proportional to the clock frequency and the memory clock has been increased by ~67% (from 400 MHz to 667 MHz).
Do I need to increase the voltage Lanboy RAM 2 May 29, 2011 10:44 AM
how to increase the performace of.... Rescue119 Video Cards 0 April 20, 2010 03:58 PM
A build to increase my PPD MarkOne New Builds 22 January 12, 2010 09:29 PM
GTX260 SP increase Shadowed Video Cards 3 August 22, 2008 12:41 PM
RAM prices to increase ? enzeo Rumor Mill 10 July 9, 2007 12:46 PM
