Old September 6, 2011, 07:54 AM
OCZ Technology - OCZ 2G DDR3 1333 PC3-10666 KIT REAPERX DCHNL OCZ3RPX1333EB2G (Ashlin.ca) at BEST PRICE im in luck then i have this ram 2 strips of 2g
and this would fit into the above board i mentioned ?
Old September 6, 2011, 07:59 AM
Soultribunal's Avatar
OCZ is actually discontinuing their RAM lineup (thankfully) so I would not get that.
Find some G.Skill (Great and Cheap) Ripjaws X or perhaps Corsair XMS3. Budget ram that is very capable from companies that have great support on their product.
And the Silencer (original series) were amazing PSU's. You're perfect there.
-ST
Old September 6, 2011, 08:13 AM
just to get an idea if this is what i would need
processor : Intel Core i7-2600K
motherboad : Asus P8Z68-V PRO
memory : ocz 4 gb ddr3
gfx : asus 480
psu : pc P & C 750w
does that sound like it would all work together and bit future proof for a couple of years ?
Old September 6, 2011, 08:17 AM
-ST
i already have that memory in my machine at the moment mate so could i continue to use it in my future machine ?
Old September 6, 2011, 08:36 AM
Ahh okay, then yes go for it. It should in theory work (though I have always had compatibility issues with OCZ) ,some boards like em, some boards don't.
Worth a shot though.
As for the rest of the setup, sounds pretty solid
Nothing is future proof but that should give you a year or two at least. Maybe a GPU upgrade when Kepler launches from nVidia.
-ST
Old September 6, 2011, 08:42 AM
-ST
good man thanks you very much for you help and imput, what started with just a cpu post has turned into a new rig
might change that mobo though havent really looked into one which is good for that chip
Old September 6, 2011, 09:06 AM
you better chek the voltage on your ram
might have to run slower speed for 1.65v
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old September 6, 2011, 09:23 AM
not sure how u do that but thanks for the pointer i will look into it once i start getting the parts
Intel Core i3-2120 & Core i5-2400 Processors Review Comment Thread SKYMTL CPU's and Motherboards 9 July 19, 2011 07:17 AM
Intel Core 2 Quad Q8200 vs Intel Core 2 Duo E8500 Hanibal{CA} New Builds 18 August 10, 2009 07:53 PM
Intel Core i7 Extreme Edition Q965 Pictured & Benchmarked MAC Press Releases & Tech News 1 October 6, 2008 12:45 PM
Intel Core 2 Extreme QX9650 45nm: TechGage Babrbarossa Reviews & Articles from the Web 4 October 31, 2007 05:32 PM
Intel releases Core 2 Quad Extreme QX6800 r00tman Rumor Mill 2 April 10, 2007 11:23 PM
