Old February 15, 2008, 01:27 PM
Default e8400 issues
Can someone stress their 8400 and check what their cpu temps do.
I just noticed with mine that the "core" temps go up but the CPU temp is frozen or doesn't move from 29 degrees.
Old February 15, 2008, 01:51 PM
What program are you uses? Try testing it with coretemp if your not using that program already.
Core Temp
Old February 15, 2008, 01:52 PM
Core Temp
Everest.
Coretemp only monitors the "cores" which I can see move.
Old February 15, 2008, 02:03 PM
Cheator's Avatar
Originally Posted by enaberif View Post
Everest.
Did you try HWMonitor?
My Heatware![/SIZE][/FONT] | Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old February 15, 2008, 02:07 PM
Eldonko's Avatar
Hardware Canucks Reviewer
That is what you want to monitor.
Old February 15, 2008, 02:13 PM
Yes thats what is showing its not moving as well as Everest :)
I know, but these chips are supposedly riddled with bugged sensors and looks like mine was one of them :D
reboot issues Jhayman Troubleshooting 7 January 23, 2008 06:00 AM
Issues with TF2. NuxTux Gaming 0 January 11, 2008 01:27 PM
4 kit ram compatibility issues? AERo RAM 3 December 19, 2007 02:15 PM
8800gtx and Far Cry - Rendering Issues Mr. Cipher Troubleshooting 9 December 4, 2007 04:00 PM
