Old February 14, 2008, 09:01 PM
mattydies's Avatar
Default BIOS Chip removal tool?
The instructions state to use a bios removal tool when removing the bios CHIP (So I can install the new one). ASUS told me "Your system not posting after flashing your bios could be the result of a residual hang of the older bios version"
Do I REALLY NEED this BIOS removal chip tool to pull off the old BIOS Chip so I can install the new one?
Intel E8400 @ 4.TWENTY Ghz & counting
Ultra 120 Ext. w/ Dual Noctua NF-P12's
Gigabyte EP45-UD3P (Rev. 1.6)
Patriot Viper (2X2GB) 1066-5-5-5-15
Gigabyte 6870 Windforce (FINALLY)
Samsung SyncMaster 225BW (22" Widescreen - 5MS)
Western Digital 74GB Raptor X 2 (Raid 0)
Seagate 750GB - SATA 2 - 7200.10
Nspire X-extreme (CWT) 750W PSU
Audigy 4 Pro, Yamaha HTR, Cerwin Vega Speakers (5.1)
Antec 900 Case
SCYTHE Fan Controller w/ 4 extra Noctua NFP-12's
Old February 14, 2008, 09:07 PM
mattydies's Avatar
My bios socket is different than the one I circled in green. It seems to clip onto the bottom of the chip.
Antec 900 Case
Old February 14, 2008, 10:01 PM
biff's Avatar
For the kind shown in the pic you can just use two thin nails or sewing needles. You work opposite corners at the same time so the chip more or less works it's way out of the socket evenly. And for god sakes make sure you don't jam the tools into the mobo traces. It really isn't a big deal but have patience and take the mobo out of the case you you have room to work. Don't do it hunched over under a desk with no light fighting off cables and videocards.
If it's much different than that then I dunno. Got a pic?
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old February 14, 2008, 10:55 PM
JD JD is offline
Are you sure you need to remove it? Have you tried clearing the CMOS? Cause that might fix your problems.
Move the jumper (CLR RTC I think) and take out the battery. Leave it like that for a couple minutes then put the jumper back to the normal position and put the battery in.
Old February 14, 2008, 10:57 PM
mattydies's Avatar
I have a bios chip like the one I circled in blue. The "Socket" if you will, is underneath the chip.
Antec 900 Case
Old February 14, 2008, 11:44 PM
mattydies's Avatar
Yes I have done this. My computer only posts about once in 10 tries, BIOS does not want to save settings
Antec 900 Case
Old February 15, 2008, 08:49 AM
biff's Avatar
Uhh any better pictures? It just looks like a regular SMT chip from here. Not much to go on.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Old February 15, 2008, 09:03 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Some BIOS chips pull right out with your fingers. All depends which it is.
Old February 15, 2008, 11:55 AM
mattydies's Avatar
I have tried coaxing it out (very carefully) with small screw drivers, picks (like a dentist tool to pick at your teeth, and paper clips. No Dice.
I think I need to use the tool.
Thanks for the input :)
Antec 900 Case
Old February 15, 2008, 12:47 PM
3oh6's Avatar
this is the little bugger you need...
came with 939 Lanparty boards if i remember correctly. either way, if your having toruble finding one, just let me know. I can fire it out to you in a bubble mailer, just ask that it comes back. with that said, getting some BIOS chips out can still be a hassle with this guy but you shouldn't have too much trouble with it. just fire me a PM if you need it.
Sapphire HD 3870 HSF Removal Tips / Help Surfer_2099 Video Cards 7 April 15, 2008 08:30 PM
BIOS Chip burning JShupka Troubleshooting 13 January 22, 2008 11:21 PM
New Bios chip / Reflash ebdoradz Overclocking, Tweaking and Benchmarking 6 January 22, 2008 08:56 PM
Antec P182 Fan Removal. Scotch Tape Cases 2 January 1, 2008 04:56 PM
Plastic cover removal on GTX magictorch Video Cards 6 December 29, 2007 03:33 PM
