Old February 27, 2007, 11:06 AM
BALISTX's Avatar
Default Budget Gaming System Challenge
Everyone likes a challenge, so here is the challenge. Your mission if you choose to take it, is to build a budget AMD gaming system for no more than $900 CDN this does not include shipping, cables, or accessories. You must have the following:
  • Processor
  • Memory
  • Motherboard
  • Graphics Card
  • Sound Card
  • Case
  • PSU (This could be included with the case such as an Antec)
  • Hard Drive
  • Optical Drive
If a part is on sale and the sale ends before March 1st you have to use the regular price.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old February 28, 2007, 05:30 PM
DerekOldschool's Avatar
AMD Athlon 64 3500+ Processor S939 Venice 2.2GHZ 512K L2 Cache 90NM Retail Box $106.08
LG GSA-H22N DVD+RW 18X8X16 DVD-RW 18X6X16 Dual Layer 8X DVD-RAM 12X DVD Writer 2MB Black OEM W/ SW $37.26
Western Digital Caviar SE16 250GB SATA2 7200RPM 16MB 8.9MS Hard Drive 3 Year Mfr Warranty $79.99
Antec Sonata Ii Black Atx 16IN Mid Tower Quiet Case 3X5.25 2X3.5 4X3.5IN 450W Air Duct 120MM Fan $112.75
Bfg Geforce 7600 Gt Oc PCI-E 256MB 128BIT GDDR3 Dual Dvi Hdtv Out Sli Ready Video Card $147.01
Samsung PC3200 1GB DDR400 184PIN DIMM Memory OEM $93.50ea x2=$187.00
ASUS A8N5X ATX S939 NFORCE4 DDR PCI-E16 SATA RAID Sound GBLAN Motherboard $90.72
Sub Total: $760.81 @ Direct Canada
No soundcard, but there's onboard sound on the mobo and thats all I'm using right now - works flawlessly - but if you really want one, there's still almost $140 to play with. If it is a gaming computer I suggest foregoing the sound card and getting a better video card with that extra $140
i7-860 @ 4.2Ghz (1.33v) • EVGA P55 FTW SLI (E657-A51 Bios) • Thermalright ULTRA-120 Trueblack Rev.C • G.Skill Ripjaws 4G DDR3-2000 • Antec 850W TPQ • 2xBFG GTX280 1G SLI • Acer X263W 25.5" LCD • Crucial C4 256G • WD FAEX 1TB • LG DVDRAM GH20NS10 • Thermaltake Kandalf case • Windows 7 Pro x64
E8400 @ 3.96Ghz (1.42v) • EVGA 780i A1 (P08) • ZalmanCNPS9700NT • G.Skill 4G DDR2-1000 • eVGA GTX280SC 1G • Windows 7 Pro x64 • 1xSeagate Barracuda 7200.11 500G
Old February 28, 2007, 05:45 PM
Babrbarossa's Avatar
Nicely done!
psst, wanna see my binder?
Old February 28, 2007, 06:25 PM
This "el-cheapo" system has alot of potential for upgrade too:
theres no sli capability, but upgrade the cpu to an opty 165 or 170, then better vid card, ram and PSU - An opty165 is less than $200 - and look what sswilson is doing with his rig; 3Ghz is awesome.
For someone with a limited budget, there are alot of possibilities if you factor in upgradeability. I was considering an AM2 rig so that he could use ddr2 ram, but then I figured it would be harder to keep it under the $900 limit - so I went with what I did
Old February 28, 2007, 06:31 PM
I know this isn't the challenge, but 900 would get you a C2D system
Old February 28, 2007, 07:20 PM
lets see YOUR shopping cart...
Old February 28, 2007, 07:35 PM
BALISTX's Avatar
AMD Athlon64 4000+ 2.40GHz SanDiego 1MB L2 Cache 1000MHz FSB - $113.99
Asus A8N-SLI-SE s939 nForce4 SLI SATA/Audio/Lan - $98.00
Crucial BallistiX 1GB Dual Channel PC3200 • 2-2-2-6 • DDR400 • 2.8V - $118.00
BFG GeForce 7600 GT OC PCI-E 256MB 128BIT GDDR3 Dual DVI HDTV Out SLI-Ready - 147.01
Creative Sound Blaster Audigy 4 SE PCI 7.1 Surround Sound Card - $49.83
Western Digital Caviar SE16 250GB SATAII 7200RPM 16MB - $79.99
LG GSA-H22N DVD+RW 18X8X16 DVD-RW 18X6X16 Dual Layer 8X DVD-RAM 12X DVD Writer 2MB Black OEM W/ SW - $37.26
SilverStone SST-ST56F Strider 560W ATX12V Power Supply W/120MM Fan Active PFC Crossfire Ready - $87.99
NZXT Apollo ATX Tower Case 5X5.25 1X3.5 4X3.5INT No PS Front Audio USB Firewire Black - $75.60
Total: $808.65
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old February 28, 2007, 11:03 PM
Misoprostol
Guest
Posts: n/a
  • Processor
  • Memory
  • Motherboard
  • Graphics Card
  • Sound Card
  • Case
  • Hard Drive
  • Optical Drive
e4300 $210
2x Crucial DDR2 512MB $76
Biostar Tforce 956PT $124
Compucase ATX chassis $24
Fortron 400W PSU $43
250GB Seagate HDD $83
Samsung DVD+-RW $35
eVGA 8800GTS 320MB $330
This system is $25 over your budget, but kicks everything else's ass.
for another $25 you can buy an LED fan or two, a bit for your dremel and a thing of spray paint and make that case look pwnage.
Old March 1, 2007, 04:22 AM
Here's a C2D for $874 direct canada- sorry for the lack of link, but my browser was acting up:
WD 250 GB HD-- $80
Creative SB Audigy 7.1-- $29
Logisys CS 51 WBK 450w case-- $40 - will eventually need to replace the psu
Gigabyte GA 965P DS3-- $164
2GB OCZ Gold PC6400-- $199
e4300-- $206
LG gSA H22N dvd burner-- $37
HIS Radeon ICEQ3 X1650 from NCIX-$119
I do like the look of Miso's with the dx10 gpu (although he omitted the soundcard) but with this sytem, I think you'd have a better overclocking motherboard and 2GB of ram-- the video card isn't so great, but you could upgrade when you could afford it. If the soundcard isn't necessary, my system would be 845. Ram is only going to get more expensive after this first quarter so it might be a good time to buy what you need.
Here's an e6300 system on sale at NCIX right now for 830:
http://www.ncix.com/products/index.p...l&promoid=1051
Old March 1, 2007, 04:37 PM
sswilson's Avatar
Originally Posted by Misoprostol View Post
e4300 $210
Samsung DVD+-RW $35
400w psu????
Not sure what the power requirements for the intels are, but I'm pretty damn sure a 400w PSU won't power that graphics card properly. :)
That said, as much as an AMD fanboy as I am, I wouldn't be building an AMD system right now.
Planned Budget System - Appreciate Opinions misterlarry CPU's and Motherboards 28 January 16, 2008 06:55 PM
My new budget-ish pc kcksteve CPU's and Motherboards 21 November 27, 2007 11:24 AM
Budget system Wiked CPU's and Motherboards 15 October 13, 2007 02:49 AM
Budget HTPC BALISTX HTPC Systems & Software 4 May 28, 2007 08:16 AM
