Old March 1, 2007, 08:15 PM
BALISTX's Avatar
What is the recommended PSU for the 8800 GTS 320MB?
Heatware
HWBOT
Old March 1, 2007, 08:43 PM
Babrbarossa's Avatar
SKYMTL's the psu expert, but I betcha a decent 500w would do ya--
Maybe this Nmedia MP 500 for 63 bucks
or maybe this 600w coolermaster for 70 bucks from direct canada
Old March 1, 2007, 09:01 PM
I'd go for something like this:
http://www.ncix.com/products/index.p...2&promoid=1051
Samsung SH-S182F DVD+RW 18X8X18 DVD-RW 18X6X18 DL 8X 2MB IDE OEM Black DVD Writer $34.99
http://www.ncix.com/products/index.p...4&promoid=1051
Biostar Tforce 965PT ATX LGA775 Conroe DDR2 965P 1PCI-E16 PCI-E1 3PCI SATA2 Sound GBLAN Motherboard $123.99
http://www.ncix.com/products/index.p...5&promoid=1051
Corsair Value Select PC2-5300 1GB 2X512MB DDR2-667 240PIN DIMM Dual Channel Memory Kit $84.99
http://www.ncix.com/products/index.p...9&promoid=1051
Intel Core 2 Duo E4300 Dual Core Processor LGA775 1.8GHZ 800FSB 2MB Retail $209.98
Antec Sonata II Black ATX 16IN Mid Tower Quiet Case 3X5.25 2X3.5 4X3.5IN 450W Air Duct 120MM Fan $109.98
Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive $103.99
http://www.ncix.com/products/index.p...0&promoid=1051
EVGA E-GEFORCE 7600 GT KO 580MHZ PCI-E 256MB 128BIT 1.5GHZ GDDR3 Dual DVI-I HDTV Out Video Card $188.98
TOTAL $856.90
Old March 3, 2007, 02:06 PM
papixx's Avatar
Here is a go at a local shop: 946.00$
AMD X2 3800+ AM2 Dual-Core Processor, Retail - 143.00
Asus M2N AM2 N430 ATX w/PCI-E/SATAII/Audio/Lan - 109.00
Kingston ValueRam 1GB PC2-4300 DDR2 - 99.00
Seagate 7200.10 250GB 7200RPM 8MB SATAII, 5Yr - 100.00
LG GSA-H22N Super Multi 18x DVD-RW (black) - 42.00
Sapphire Radeon X1950GT 256Mb Dual DVI (Lite) - 211.00
Creative Labs Sound Blaster X-Fi XtremeMusic - 114.00
Antec SonataII Mid-Tower Case w/450W PS, Black - 128.00
http://www.shoprbc.com/ca/shop/produ...p?coid=5008362
b m x e r @ e o c f
Old March 3, 2007, 02:25 PM
sswilson's Avatar
Something I've noticed in quite a few of the builds is single sticks of mem....
I'm no expert, but AFAIK you're giving up a hell of a lot of mem bandwidth by not taking advantage of dual channel.
Probably an extra $20 or so for 2X512 sticks, but it would probably be well worth it.
Old March 3, 2007, 07:48 PM
papixx's Avatar
At this point, I'd rather get a single 1gb stick and be able to buy a second stick in the futur, then utilise the dual-channel . Using dual channel give you about 5% max better performance.
1 stick now, another later.
b m x e r @ e o c f
Old March 10, 2007, 08:49 AM
Originally Posted by Misoprostol View Post
e4300 $210
2x Crucial DDR2 512MB $76
Biostar Tforce 956PT $124
Compucase ATX chassis $24
Fortron 400W PSU $43
250GB Seagate HDD $83
Samsung DVD+-RW $35
eVGA 8800GTS 320MB $330
This system is $25 over your budget, but kicks everything else's ass.
for another $25 you can buy an LED fan or two, a bit for your dremel and a thing of spray paint and make that case look pwnage.
i joined just to go "wtf, a 400w psu?" i had a 400w fortron, and it wouldn't power my system with a x1950xt in it.
  #19 (permalink)
Old March 11, 2007, 06:18 PM
gescores's Avatar
Hi everyone, first post here with a link to a nice PSU calculator
you just need to replace the ,
web,aanet,com,au/SnooP/psucalc,php
  #20 (permalink)
Old March 11, 2007, 06:42 PM
b1lk1's Avatar
I hate to say it, but not only should it have worked, it should be able to power more stuff than that list. I have run SLI and Crossfire with 500W PSU's with no problems.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Planned Budget System - Appreciate Opinions misterlarry CPU's and Motherboards 28 January 16, 2008 07:55 PM
My new budget-ish pc kcksteve CPU's and Motherboards 21 November 27, 2007 12:24 PM
Budget system Wiked CPU's and Motherboards 15 October 13, 2007 02:49 AM
Budget HTPC BALISTX HTPC Systems & Software 4 May 28, 2007 08:16 AM
