Old July 31, 2011, 08:21 PM
whats the best program to monitor cpu? I can then post a log anyways.
Old August 2, 2011, 01:10 PM
So I ran a few tests with furmark and 3dmark. I oc my gtx460 a little which did improve the overall score however, playing/testing a few games I didnt see my fps change all that much. So I am assuming that its my cpu that bottle necking.
Old September 28, 2011, 06:46 PM
I don't think that is neccessarily what is happening. An average overclock might boost your average frame rate by 3-10 fps so don't expect the world.
Old September 28, 2011, 07:17 PM
Killswitch's Avatar
I agree with Freefall. Almost every video card I've owned didn't gain much in real world gaming when overclocked. At least not enough to make a major difference, although some games you'd gain more then others of course. YMMV. As for benchmarking though, most definitely worth while for seeing if you can beat your buddies score! haha
I doubt your Athlon II x3 @ 3GHz would bottleneck a single GTX460 in any circumstance. A good way to check is to lower the resolution waaaaay down and see if the FPS increase. If it stays the same or doesn't go up by very much you've got a cpu bottle neck.
Old September 29, 2011, 06:40 AM
Most games I would say it isn't going to be a large cpu bottleneck, but BF seems to be well threaded and use CPU well. That said the only good info on CPU scaling so far is for BF BC2. Here is a chart I found and let you draw your own conclusions if it would be worth it to upgrade for BF3...IMO probably would help out.
Only amd processors worth considering for you would be x4 955 or x6 1090 IMO (probably x6, but this review didn't include and x6 for comparison). BF BC2 seems to like L3 cache and cores. 955 and 1090 are cheapest black edition x4 and x6 so could be OC to speed of higher models if you want it.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Pc for bf3 captain kenpachi New Builds 8 May 26, 2011 12:54 AM
CPU upgrade Mr. Gruntsworthy New Builds 20 February 17, 2011 04:07 PM
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
CPU upgrade mo' power CPU's and Motherboards 10 July 28, 2009 09:10 AM
Best CPU upgrade??? Delavan New Builds 11 April 2, 2009 07:41 PM
