<~----> sata 6bg question - Hardware Canucks
Old July 29, 2011, 11:04 AM
kyle_L's Avatar
Default sata 6bg question
never really bothered to read up about sata 6gb, but i plan on upgrading my computer over the next few weeks and wanted to know if i can use sata 3gb drives on the 6gb ports.
im looking for work.
Old July 29, 2011, 11:24 AM
krazyups's Avatar
IIRC, SATA 6gb is backwards compatible with SATA 3gb, so it should be no problem.
Old July 29, 2011, 11:32 AM
Galcobar's Avatar
Backwards compatible.
Old August 7, 2011, 02:03 PM
JimboToronto's Avatar
Since most (all?) SATA3-capable mobos also include SATA2 ports, I'd simply use SATA2 for your older SSDs and HDDs and save the SATA3 ports for newer drives as you add them.
Old August 7, 2011, 02:18 PM
kyle_L's Avatar
kinda hard to fit 8 sata drives on 4 ports, and the ports work fine for sata 2 drives.
Old August 7, 2011, 03:02 PM
8 SATA drives internally? Wow. I guess you probably use RAID. That reminds me of the bad old days before USB2 when you had to get a full-tower server case to hold all the internal HDDs required to assemble an array of less than a terabyte.
Or do you use eSATA for some of them?
That's a lot of heat to dissipate and watts on your PSU. With the advent of USB3, I prefer to keep all mechanical HDDs outside the box on their own power supplies.
You say you're planning your mobo upgrade? Some MBs are well supplied with SATA ports. Mine has 4 SATA3 (2 Intel + 2 Marvell) and 6 SATA2 (4 internal 2 eSATA). The SATA3 ports are strictly for SSDs. HDDs come nowhere near saturating SATA2 and are barely even bottlenecked by SATA1.
If in your case you're only using SATA2 devices, SATA3 is obviously not an issue as it's indeed backwards compatible.
Old August 7, 2011, 03:58 PM
BootlegUsher's Avatar
Now that the original question has been answered, I have one of my own. I have read posts on various forums referencing that intel sata 6g controlers are superior to AMD's, and SSD's will be faster on intel systems.
1. Is this true
2. If it is true, is it a big difference or only the kind of thing you will see in benchmarks.
Old August 7, 2011, 04:15 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Yes it is true, will you notice the dif in real life....depends on what you use the rig for and what SSD you are using.
If you are a normal user and you have say a 240GB Vertex 3 MI / Mushkin Chronos / Pat Wildfire....no way. If you are a power user...maybe a second here and there.
Now if you have an older Sata 6'er like say the C300 that doesnt have power to burn...then maybe you will notice it. I personally notice it on my amd rig and M4 256GB...but the difference is not night and day. At worst you are looking at probably low double digit percentage dif and at best single digit performance difference.
Pci to sata and boot drive question alberto Storage 7 July 28, 2011 10:29 PM
SATA II HDDs in a SATA III port ivanlyf_2011 Storage 6 April 6, 2011 05:32 PM
[WTT] Toronto: 2 sata data and 1 sata power cable 0o0 Buy/Sell & Trade 3 August 11, 2010 09:09 AM
[FS] WTT/WTS DVD's for cash/sata optical drive/sata hdd's/ Geforce 9800 or better The MAX Buy/Sell & Trade 4 April 16, 2009 04:22 PM
WD 640 Black SATA ....Not SATA 2 rjbarker Storage 10 January 19, 2009 11:40 PM
