View Poll Results: What's your pick; A6 or i3?
A6-3400m 14 60.87%
i3-2310m 5 21.74%
Other... 4 17.39%
Voters: 23. You may not vote on this poll
Old July 23, 2011, 09:20 AM
Bond007's Avatar
Default A6-3400m vs i3 2310m
Need some help on deciding which way to go...i3 or A6. I know either will be more than powerful enough for its main purpose of web surfing, HD videos, etc. Problem is I am going to be running whichever I get on integrated graphics and mainly gaming with Starcraft II (possibly some others, but SCII is primary) on 15.6" at 1366x768. I know the A6 has a faster GPU and i3 has a faster CPU, but SCII is heavily CPU dependent. I have not found any reviews that put these 2 processors head to head in SCII. Obviously the higher I can run the graphics the better, but I am mainly after smooth game play. I am not getting a dedicated graphics card unless I find a deal I cannot refuse.
What's your vote; A6 or i3?
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old July 23, 2011, 09:27 AM
since you mentioned graphics and gaming the apu for the win. forget the i3.
Old July 23, 2011, 09:47 AM
jcmaz's Avatar
How bout the i5 2410m???
-Plato
Old July 23, 2011, 11:46 AM
chubaka's Avatar
‪AMD Llano A6-3400M with Radeon 6520G for Starcraft 2‬‏ - YouTube
seems to do fine at low settings avg 60-70 and dipping to low 30's when there are more units on screen.
Old July 23, 2011, 12:41 PM
Bond007's Avatar
If I could find a good price on a 2410m I would definitely consider it. Graphics portion would be the same as 2310m though. Probably going to bump cost up (looking for a laptop in the $500 range).
A good video to somewhat push my point. While that shows the game running fine in a 1v1 game, its framerates drop substantially as units on the screen increase. I am thinking that drop is a lack of CPU power and that maybe an HD3000 (in i3 or i5) would have lower fps initially, but be able to better maintain it as more and more CPU power is required with hundreds of units (3v3 or 4v4 game).
That is exactly what I was thinking initially, but then I started wondering if maybe the i3 would hold up better as per what I mentioned above.
Old July 23, 2011, 01:08 PM
if you need the machine for cpu power then look for the i5,or i3. else? dont beat your right hand when it points towards the apu :)
Old July 24, 2011, 01:07 PM
why not get the a8-3850 instead?
Old July 24, 2011, 01:56 PM
Bond007's Avatar
$...there is always something better if you have the money to go for it.
From what I have seen so far a6 are priced $500-$650 and a8 >$650
A chart for a8 vs i5...as close as I have found to SCII a6 vs i3
a8 has better avg, but lower min. Wonder what the a6 cut down gpu will do for performance.
Old July 24, 2011, 04:06 PM
Bear in mind those are at high details. Its always possible to lower the details to get better FPS.
Old August 18, 2011, 05:13 PM
Also remember that the Llano's battery will outlast the SB's by 45 minutes when gaming. :D
A6-3400m overclocking Fudd Rucker Overclocking, Tweaking and Benchmarking 3 July 10, 2011 10:58 AM
