View Poll Results: What's your pick; A6 or i3?
A6-3400m 14 60.87%
i3-2310m 5 21.74%
Other... 4 17.39%
Voters: 23. You may not vote on this poll
Old August 21, 2011, 12:45 PM
I just picked up the Gateway NV57H i3-2310m from FS with the express purpose of testing it against the llano with sc2.
Watching a replay of huk that lasted 35ish minutes, once 2 max army attack onscreen, the i3 drops to around 18fps with all settings on low. I'll be grabbing the llano on Tuesday to complete the same test, and I'll give my results for that then hopefully.
Old August 21, 2011, 02:01 PM
Bond007's Avatar
look forward to seeing the result.
Old August 24, 2011, 10:16 AM
Went to pick up the laptop on Tuesday and they were sold out. Got a raincheck and will likely be picking one up on Friday now. Details then.
Old August 24, 2011, 12:43 PM
Bond007's Avatar
still looking forward to it. Keep us updated.
Old August 26, 2011, 01:36 PM
So, just ran the same replay on the A6-3400m. Average framerates were MUCH higher than the i3. It still dropped to mid/high teens when there were 2 max armies battling it out, i think mainly due to the fact that a ton of forcefields were thrown down in rapid succession. Either way, I will be sticking with the A6 as I've come to understand that it is easily overclocked to 1.8ghz from 1.4 with no issues. This should throw the a6 firmly in the better budget gaming computer over the i3. Remember though, all these settings are on low low low. Additionally, since this only cost me 429$, I'd say it's a steal!
Hope this review helped those with similar questions.
Old August 26, 2011, 08:56 PM
After a little fiddling and searching, I found out how to overclock the llano a6 to 1.8ghz. By doing this, I was able to play on full medium settings of sc2 with very decent frame rates(minimum was nearly identical to that of the non-overclocked on low graphics)
Impressive to say the least!
The frames started at approx 60fps and dipped as low as 12(though only briefly at the start of a large max army battle) Majority of the time, it was at 25fps mid-late game. I can only imagine the frames would be much higher on the low setting, but I didn't test that yet. Anyway, it seems that AMD has this processor underclocked from where it should be set at default.
Old September 6, 2011, 10:16 AM
Varroa's Avatar
You may be able to help out your frame rates if you can upgrade the system memory to something faster. Those APUs are memory speed starved and since they use the same memory as the system you can increase your APU speed with faster system memory. Check to see what your laptop supports and if you can then replace the memory with something faster.
Testing Different Memory Speeds on AMD's A8-3850 Llano APU - Memory Performance on AMD's A-Series APU - Legit Reviews
http://www.guru3d.com/article/amd-br...50-apu-review/
AMD A8-3850 Llano Desktop Processor Review - Can AMD compete with Sandy Bridge? | Memory Speed and its Effect on Graphics Performance
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
A6-3400m overclocking Fudd Rucker Overclocking, Tweaking and Benchmarking 3 July 10, 2011 10:58 AM
