Old July 22, 2011, 06:53 PM
Default Need some help
Hey guys, I have a problem where when I boot my computer there is no display signal and the whole computer becomes unresponsive. I am using a gigabyte GA-P55A-DS3L.
I have already tried two different video cards, both didnt work.
I have also tried reseating, and testing each single stick of RAM individually.
I am fairly certain the RAM is the issue since my keyboard will not even light up and when I disconnect the PCI-E power connector the computer does not make a sound.
I want to ask if you think it could be something else? Or something else I can try. I have no problem going tomorrow to get some RAM but I just want to be sure
Old July 22, 2011, 07:04 PM
ZZLEE's Avatar
Try other Slot fore Vidio Card ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old July 22, 2011, 07:07 PM
post the whole specs plz
could be anything,including the mobo.
put it together on your table,check again
Old July 22, 2011, 07:18 PM
Well here are my specs:
Sapphire ATI 6850
ATI 5670 (test card)
i5-750
Some old Mushkin DDR3 RAM
Antec Truepower Trio 650W
Gigabyte GA-P65-DS3L
I basically put the computer back together.
I tried both slots of the mobo with both cards. I believe the motherboard isn't even going to post.
The fans and everything start to spin up but still nothing is displaying.
Also I know the other card works since my brother is currently playing CSS with it
Old July 22, 2011, 08:11 PM
does the cpu fan spin at full bore or it slows down after a few secs(good sign)?
do a bios reset just in case, reseat cpu too as a last resort.
unless you can swap everything? you can always have a doubt.
Old July 22, 2011, 08:18 PM
Well I already reset the BIOS, and the CPU fans are plugged into my fan controller not the mobo.
I don't think it could be the CPU since I have been running it at stock voltages and have had it for barely a year.
Old July 22, 2011, 08:52 PM
if you swapped everything but the mobo and cpu,between those two the mobo will go first,usually.
if you swapped everything :)
and take out the fan controller,plug the cpu fan in its rightful header
Old July 22, 2011, 08:54 PM
Yeah I will try that tomorrow. I think I will still buy the RAM, my Mushkin RAM is the older DDR3 left over from a LGA775 build so it could be that.
Also if the fans dont spin down what does that mean?
I have seen RAM do similar things before so I would assume it was that before it was the mobo
Old July 22, 2011, 09:08 PM
good. well if it worked before,maybe.
usually once you reset it,and it completes boot(even if you dont see video)
they spin down. never spin down? either it doesnt complete boot,or in some cases(more rare) its normal.
Old July 22, 2011, 09:28 PM
Yeah I believe it is not even completing boot which I know bad RAM can cause.
Thanks for all your help I will post tomorrow on whether the new ram helped
