Old July 22, 2011, 10:07 AM
sakage.shinga's Avatar
Default Should I upgrade from i5-750 to i7-875K?
Hi guys,
I currently have an i5-750 (no HT) OC'd at ~3.2GHz, but my mobo (Asus P7P55D Pro) actually supports the i7 series, as well. I'm thinking about upgrading my CPU to the i7-875K (unlocked) with HT, but I'm not sure how much of a performance boost I'd see in terms of gaming (Battlefield 3, Witcher 2, Crysis 2, Skyrim, etc.) Right now I can play my games basically at max settings, but I can see that my CPU will be the bottleneck ahead of my videocard.
Should I bother going through the hassle of upgrading my CPU? I'll only do it if there's going to be a noticeable performance boost.
Thanks!
Intel Core i5-750 OC'd @3.06 GHz
Asus P7P55D Pro
Cooler Master Hyper 212 Plus
8GB (2x4GB) G. Skill Ripjaws X-Series
Asus Radeon HD 6970 DirectCU II 2GB
Asus Xonar DX
WD Caviar Black 640GB
WD Caviar Black 2TB
WD Caviar Green 3TB
SilverStone Strider Plus 750W Modular
Cooler Master 690 II Advanced
Windows 7 Home Edition 64-bit
Logitech G9 Gaming Mouse
Razer BlackWidow Mechanical Keyboard
Old July 22, 2011, 10:15 AM
i would move more towards a 2500k build vs getting an i7 for your mobo, but that's just me.
if you have no issues whatsoever,though, leave it be.
Old July 22, 2011, 10:31 AM
i5-2500K isn't listed as a supported CPU for the P7P55D Pro mobo, which is 1156 socket vs. the 2500K's 1155 socket?
Asus P7P55D Pro
Asus Xonar DX
WD Caviar Black 2TB
WD Caviar Green 3TB
Old July 22, 2011, 10:43 AM
No point in going for a processor that's virtually identical in performance in terms of gaming. Even if you had a need for 8 threads an X3440 is much cheaper and will overclock just as well. Not to mention it's an older platform.
Old July 22, 2011, 11:37 AM
right you would need mobo+cpu..and perhaps ram too if yours isnt 1.5 volters
Old July 22, 2011, 12:07 PM
yycraven's Avatar
If you plan on keeping it for a while, then just upgrade to the i7-875K. You should see a difference in performance.
If your want to get a whole new system, then get a 2500K.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old July 22, 2011, 02:31 PM
IMO you will see little to no difference in gaming between the 750 and 875. The only way that upgrade would be required is if you are doing CPU heavy computing that can take advantage of hyperthreading (gaming does not). I would NOT do that upgrade if I was you. If you need an upgrade for gaming you will have to make the shift to sandy bridge (socket 1155 and 2500k/2600k).
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old July 22, 2011, 03:34 PM
just overclock your cpu to 3.8-4.0
p55 is fast in games as it is
if you like me want the xtra 10% then go 2500k
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old July 22, 2011, 05:33 PM
Fudd Rucker's Avatar
You wont notice any diff in gaming. I did the same switch last year when I went from a 750 to an 860 and noticed zero gaming difference. Working on the other hand was like night and day.
I couldnt think of something snarky or interesting to put here this time around.
Old July 25, 2011, 12:38 PM
Thanks for all the replies. Guess I'll save my money until I build a new rig a few years down the road. Might even put it towards a new video card in the near future...those 4gb ram cards will be awfully tempting once they drop down to $300 or so...
Asus P7P55D Pro
Asus Xonar DX
WD Caviar Black 2TB
WD Caviar Green 3TB
upgrade from i5 750 muffler CPU's and Motherboards 7 October 21, 2010 11:49 AM
[WTB] WTB: Intel 875k or i5 655k MarcusFoX Buy/Sell & Trade 5 October 1, 2010 03:15 PM
preliminary results on my i7 875K mo' power Overclocking, Tweaking and Benchmarking 2 August 31, 2010 10:19 PM
i7 875k or 930? (Plus more advice please) Cisco99 New Builds 8 July 27, 2010 10:43 AM
Personal upgrade experience from C2D to i5 750 mjpd1983 Gaming 5 July 19, 2010 12:40 PM
