Old July 18, 2011, 12:17 PM
gd65? :)
between that the ud4 and the sabertooth its a tough choice.
Old July 18, 2011, 12:18 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Hard to say, I would probably buy the ASUS personally. If you want a cheaper board you might consider something like a Z68A-D3H as well. Tough to beat for $130.
Old July 18, 2011, 12:19 PM
Originally Posted by MrDiaz View Post
Alrighty sounds good..
Out of these selections.
- MSI P67CS-C43
- ASUS P8P67
- MSI P67A
- Gigabyte GA-P67A-D3
What do u think would be the best choice?
If you're going to push over 4.2ghz, I wouldn't touch any of those boards except the Asus. Not because it's a better board, but because it's the only one that will throttle your CPU to prevent VRM failure.
Old July 18, 2011, 12:21 PM
MrDiaz's Avatar
Interesting, will probably going to have to go with either that, the UD4 or something higher.
As you can see I'm trying to get a low cost board that could stand the 4.5Ghz-5Ghz range
-- Viva Canada! --
Old July 18, 2011, 03:43 PM
BootlegUsher's Avatar
Hey guys, I read on another site that it is possible to create a partition on your SSD to use for caching. With a 128gb SSD you could use 20gb for caching and the rest as a C: drive. This means that you could have 100% SSD speeds on the things you put on the SSD, and your hard drives get the boost as well. That sounds like one fast system.
rams for 1366/1155 skydealseeker RAM 3 March 22, 2011 08:27 PM
1155 ram severity RAM 1 March 22, 2011 06:50 PM
Cooler for i5 2500k - 1155 JPHarry Air Cooling 8 February 25, 2011 02:18 PM
1155 dilemma: ASRock vs Asus writhen CPU's and Motherboards 67 January 30, 2011 01:56 AM
T.R.U.E on 1155? Dr_BenD_over Air Cooling 2 January 10, 2011 03:05 PM
