Old July 18, 2011, 12:54 AM
Default System 32?
When i turned my rig on today it said the following error message: Please instal the following hardware. System32...File is broken please replace it .... or something like that. WHAT DO I DO?! Please help.
Old July 18, 2011, 01:20 AM
supaflyx3's Avatar
boot your windows CD up and do a repair install.
Old July 18, 2011, 01:24 AM
What CD may you be talking aboot?
Old July 18, 2011, 04:07 AM
supaflyx3's Avatar
The one you used to install windows with..
Old July 18, 2011, 09:22 AM
or go to the repair console thingie and try a fixboot , fixmbr?
havent fiddled with those in a while :)
Old July 18, 2011, 09:29 AM
A broken System32 will not be fixed with a /fixmbr or /fixboot
You will need to go through a much bigger process or try booting with "Last Known Good Configuration" if you can or get into System Restore and go back to the last one.
Otherwise those errors usually result in a reinstall as its the registry which is broken.
Old July 18, 2011, 05:59 PM
ipaine's Avatar
Considering this is windows 7 then what you should do is like someone said boot to your windows 7 disk. At this point let the start up repair try to automatically fix it for you. If it does not then your next choice would be to run a system restore from the disk as well. Hopefully that should do it.
You can find a decent how to and screenshots here:
Using System Restore - Windows 7/Vista
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old July 18, 2011, 06:14 PM
Shadowmeph's Avatar
If this is a windows xp OS then I would say that you possibly have a virus there are some free downloadable repair disks out there that repair a variety of OSs but the easiest is to do what has been suggested so far
Old July 20, 2011, 09:07 PM
Thanks so much i thought i lost her/
Old July 21, 2011, 07:21 AM
I'm not a big fan of system restores etc but in your case you perhaps need your data but always "ALWAYS!" make sure you have backup of critical data like pictures and documents.
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : ASUS Sabertooth P67, i7 2700K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, EVGA 660, Corsair 1000HX, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Gigabyte 770, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 120
Not sure which system is better. slaweko New Builds 4 December 12, 2010 06:44 AM
Value of My System SneakySnake Off Topic 6 April 7, 2010 06:18 AM
New i7 System prozac26 New Builds 11 January 11, 2010 05:43 PM
system value misterd Off Topic 7 August 25, 2009 07:21 PM
Which system is better?? Barber New Builds 42 March 14, 2009 01:15 PM
