Old July 15, 2011, 04:08 PM
Default Help
My friend called me today and told me he turned off my CPU Fan/heatsink three days ago and ive running for three days without the fan. What should i do...Beside killing him?
Old July 15, 2011, 04:10 PM
Uhmm did you check to see if it was off?
No computer will run for 3 days without the CPU fan.. Too many things in place as security measures
Old July 15, 2011, 04:12 PM
See if what was off ive been gaming on a casual basis for three days and when he told me that i checked and it was off.
Old July 15, 2011, 04:15 PM
supaflyx3's Avatar
There is no way to turn off a CPU fan without physically unplugging it, open up your case and plug it back in.
Old July 15, 2011, 04:53 PM
PerryC's Avatar
After you have done that you have two more steps:
1. Ask your friend why he did it,
2. Then take out your frustrations on your friend
Old July 15, 2011, 04:55 PM
maverick_brent's Avatar
If ur computer still runs ..plug it in and curse your friend for making it run warmer ..it it doesn't .....kill him
Old July 15, 2011, 05:34 PM
Guys if he is gaming and the fan wasn't running less than 5 minutes running that machine it would shut down to due heat or thermals.
There is no way it'll run for 3 days without a fan.
Old July 15, 2011, 05:40 PM
laugh at his joke?
stock cooling will not be able to make it thru a day, even with heavy throttling on the cpu.
now if you have a nice hr-02 or the like and the fan is not working? ok.
Old July 15, 2011, 06:12 PM
I didst look at the op stats..but I also don't see his cooling there when I did maybe he is hr_02
Old July 15, 2011, 06:46 PM
make the computer was alright being passively cooled, you never know.
