Old July 14, 2011, 05:23 AM
SKW's Avatar
SKW SKW is offline
Default Can I get some opinions on this Mobo
Hello HWC's,
I am build an i5 gaming machine and am looking at this motherboard
  • MSI P67A-G45 (B3) P67 ATX LGA1155 DDR3 2PCI-E16 3PCI-E 2PCI CrossFireX SATA3 USB3 Motherboard
I have always used Asus boards but looking for a change.
Is this board ok?
Thanks
SKW
Old July 14, 2011, 07:23 AM
msi's building some fine mobos for the last few years.
even the value oens are decent.
just look up board layout,or rather componentry,before you want to match it with
your intended cpu/purpose(i.e. oc)
~$2000 New Build! Mobo/GPU/CPU Expert Opinions Needed! blinkdagger New Builds 6 June 21, 2011 12:06 PM
Opinions on best looking 1155 Mobo for cheap bkh2 New Builds 5 June 5, 2011 06:45 PM
860 MoBo Choice - Need Some Opinions UnknownSoldier CPU's and Motherboards 35 November 30, 2009 09:58 AM
Build almost decided, need opinions on mobo + cooling Peppaaro New Builds 15 October 4, 2008 12:20 AM
opinions on this mobo Jim CPU's and Motherboards 6 July 26, 2007 08:23 PM
