Old February 6, 2008, 01:39 PM
Default Building a Dual Socket System
Hi folks. I am looking to build a dual socket system with 2 Xeon 5410's on a Supermicro board. I am hoping that someone can tell me the following:
Is building a dual socket system substantially different from a single socket system? Are there special considerations, processes, procedures, that are different or more complicated?
I have been assuming that the only difference was installing two proc's instead of one.
If there are any differences and anyone can point me towards resources/info online, I would appreciate it.
Thanks
Paul
Old February 6, 2008, 01:46 PM
Thanks
Paul
The only major difference your gonna find with building a dual socket board is that they are usually server boards which end up needing ECC memory which can raise the cost.
Old February 6, 2008, 02:09 PM
Thanks Enaberif. Ya I have sourced the parts I am going to use, which includes FB ECC Ram. It's taken a ton of research but I think I am pretty good for my parts list. I am more concerned with differences in the actual build process. Any thoughts?
Thanks
Paul
Old February 6, 2008, 02:11 PM
Thanks
Paul
Again no difference at all its just like building a single socket board except you have two sockets :D
Dual socket machines are a riot to work with as its amazing to see two cpus work together.
Old February 6, 2008, 02:30 PM
CMetaphor's Avatar
Quadfather
Don't forget the cpu coolers! Larger tower heatsink and some of the smaller wider one wont be able to clear one another on the board. So make sure to get two that fit nicely on your board without interfering with eachother. Another thing along the same lines - If you can get coolers that can orient in any direction do so, cause sending the heat "towards the back" of the case will cause one processor to shoot its heat at the second. Instead, if you can get ones that orient in any direction, make them both shoot their heat upwards.
Old February 6, 2008, 04:14 PM
does the board your getting support overclocking? I've got a Tyan dual socket board its its got Zero overclocking features.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old February 6, 2008, 04:15 PM
Server boards are designed for stability not performance so in general you will not be able to overclock most server boards.
Old February 6, 2008, 04:22 PM
3.0charlie's Avatar
Unless you're willing to wait for Skulltrail.
Hydro-Quebec is salivating...
Old February 6, 2008, 05:01 PM
Ugly n Grey's Avatar
There's PSEL mods for some of the CPU's and that's about it. Memory can be tweaked a bit via software but not much of that either. Skulltrail for a 100 bucks more is the best bet for an enthusiast tweakable rig.
What to DO and NOT DO when building a PC. Moneyless Guides & How-to's 41 December 7, 2009 06:19 PM
Building a new rig, need help(im new) NoobLordSpud CPU's and Motherboards 22 July 10, 2007 07:53 AM
Socket A. I still have it! Il Duce CPU's and Motherboards 10 April 13, 2007 10:20 AM
I have a BOXX dual AMP 2200+ system that i believe is overheating maytagazn Troubleshooting 3 April 11, 2007 08:11 PM
