Old July 3, 2011, 07:14 PM
Apathetik's Avatar
Default Is my Xeon 3350 CPU compatible with this motheboard?
Hello just wondering if my Intel Xeon 3350, is compatible with this motherboard?
GIGABYTE - Motherboard - Socket 775 - GA-P45T-ES3G (rev. 1.3)
I see that the Core 2 Quad Q9450 is compatible with it, and that my Xeon has the same specs as this CPU. I am currently on an EVGA 780i 132CK motherboard. I don't see any problem since they're both Yorkfields, but I am not entirely sure. I have read that Xeon 3350s work with mostl motherboards, but just checking here :)
P.S. - Do you think this is a decent upgrade, if this motherboard is compatible with my processor if I were to also switch from 4gb DDR2 1066mhz, to 8gb of DDR3 Dominator 1600mhz ram as well for around $200 total?
Thanks HWC.
ASUS VE278Q 27" LED / DAS Professional Model S Cherry MX Blue Mechanical / Logitech G500 - QcK Mass / Corsair Veng 2000 / Windows 7 Ultimate 64bit
Old July 3, 2011, 07:40 PM
perhaps but why go sideways AND spend money? :)
Old July 3, 2011, 08:23 PM
Apathetik's Avatar
Having some hardware issues with my computer hard locking constantly, and really slow boots that are hanging in the start screens then finally loading windows. Don't know if its PSU, or ram.
Figure if I just get a new mobo, ram and psu it should fix it, and I can use my old processor and possibly overclock it higher too after reading reviews about this Gigabyte mobo. I would also have more memory and for a minimal price, I believe personally its a decent upgrade, especially if I can get my cpu to 3.6 or something. I believe its better then going i7 sandy bridge at the moment cuz I don't really want to drop > $1500 on a new rig.
Old July 3, 2011, 11:46 PM
Apathetik's Avatar
Anyone :(
Old July 4, 2011, 12:38 AM
you could try a 2500k build
but going back to your q's..yes it should work(bios forgiving)
but memtest your rig. first. see if heats an issue. those chippies go hiroshima
although those boards are quite popular with the recyclers :D
Old July 4, 2011, 04:45 AM
Arinoth's Avatar
Just to let you know socket 775 does not support DDR3 RAM at all so switching/trying to upgrade your ram to that would be rather moot. From what I can see they are essentially the same processor so you would get little to no performance increase at all. If you're looking to spend money and actually see a difference your best bet is probably to sell your old parts and move to Sandy Bridge, probably a 2500 or 2500k if you want the ability to overclock
[WTB] RDRAM (512mb or more, total), XEON 1.7 or Paired 603 CPU's clone63 Buy/Sell & Trade 1 February 20, 2011 08:59 AM
Motheboard BIOS? Gooses New Builds 4 June 24, 2010 06:09 PM
help with a motheboard selection ghostlycharms New Builds 2 May 17, 2010 12:10 PM
Overclock & Voltage on Xeon 3350 Apathetik Overclocking, Tweaking and Benchmarking 13 July 22, 2009 06:11 PM
[FS] Xeon E5420 771 CPU's (2) mmansueto Buy/Sell & Trade 2 March 10, 2009 01:48 PM
