Old July 1, 2011, 04:05 PM
Default quick question
Does a motherboard come with a operating system installed ....and if not can i install one with a external burner
Old July 1, 2011, 04:12 PM
some have a flash thingy with linux on it or you can just pop in your favorite distro
and use it like that or install it to hdd.
Old July 1, 2011, 08:15 PM
Silvgearx's Avatar
All mother board comes with pre-loaded BIOS if that is what your asking.
Old July 2, 2011, 05:31 AM
Motherboards don't come with enough internal memory storage to hold a full OS, although they obviously have BIOS or UEFI that can load an OS from internal / external CD-ROM drives, internal / external hard drives, or USB flash drives (although the last couple BIOSes I got were very temperamental in trying to load an OS off a USB drive).
I installed Windows 7 using an external DVD-RAM drive before. You just have to set your BIOS to boot from external CD-ROM (sometimes shown as USB-CDROM or something in the options) and you're good to go.
quick question twleung RAM 5 January 24, 2010 03:46 PM
Quick Question Shonoby Display Units 2 July 9, 2009 03:58 PM
Quick question Zippoh New Builds 10 December 2, 2008 08:48 PM
quick question... omgwtf O/S's, Drivers & General Software 14 July 22, 2008 05:31 PM
Quick question Nodscene Power Supplies 2 July 7, 2008 11:27 AM
