Old June 26, 2011, 06:08 AM
metalcore's Avatar
Default CROSSHAIR V HELP :)
I recently upgraded my computer with a Asus crosshair V board. With it I am using a Phenom 2 955 BE,
ocz vertex 2 60gb, a pair of 4890s in crossfire, 8GB gskill ram and Windows 7 64.
My problem is that when I first booted my pc after I finished installing everything, instead of having my cpu with the default specs including voltage, I got my phenom 2 955 at 3467.6mhz and 1.404 V.
Even when I press the clear cmos button, remove the board battery or press f5 in bios to load defaults,
as soon as I load the operating system, my cpu settings go back to 3467.6mhz and 1.404 V.
Any ideas?
Thanks in advance.
_____________________________________
-Cooler Master HAF X
-Asus Crosshair V
-SAPPHIRE 4890 " CROSSFIRE"
-Corsair H60
-OCZ VERTEX 2 60GB
-Phenom II 955 black
-wd velociraptor 300g sata hd
-wd caviar black 750gb sata hd
-wd caviar green 1000 sata hd
-8gb (2x4) GSKILL RAM
-lg blu-ray drive
-asus dvd/cd drive
-enermax galaxy 1000W PSU
-Kingston card reader
-Windows 7 Ultimate 64bit
Old June 26, 2011, 06:54 AM
Reyzac's Avatar
Man, you're complaining about a somehow automatically-placed stable overclock on your CPU. That's not a problem, bask in the improvement!
Who needs a real doctor when you got my machines and their scary needles?
I also go by Silver Blues in lots of other places.
Old June 26, 2011, 07:38 AM
metalcore's Avatar
Hahahhaa..Thanks
What should I do to get my computer to boot in stock settings?
I prefer to overclock it manually myself.
I am able to get into bios, change the settings and save but when I log into OS, it goes back to 3.4ghz
-Asus Crosshair V
-Corsair H60
-OCZ VERTEX 2 60GB
-lg blu-ray drive
-asus dvd/cd drive
Old June 26, 2011, 03:48 PM
NSdeadly1's Avatar
Did you use TurboV to oc your cpu? If so you may have to uninstall it. Also check to see if the "level up" option is enabled in bios. I had a similar glitch with my p7p55d-e and had to uninstall TurboV and reset CMOS for it to go away.
Old June 26, 2011, 08:43 PM
metalcore's Avatar
Yes I used turbo V one time and after that I just deleted the software because it was adding too much voltage to my chip. It overclocked my chip at 3.7ghz but the voltage was too high.
I will check the settings that you mentioned.
Hope it works. Thanks!
-Asus Crosshair V
-Corsair H60
-OCZ VERTEX 2 60GB
-lg blu-ray drive
-asus dvd/cd drive
Old June 28, 2011, 09:43 AM
metalcore's Avatar
That's weird. I was checking to see if it had anything to do with my ram and when I set it from1600 to 1333, everything works just fine.
I will probably have to change these ram sticks.
Thanks for your help!
-Asus Crosshair V
-Corsair H60
-OCZ VERTEX 2 60GB
-lg blu-ray drive
-asus dvd/cd drive
Old June 28, 2011, 10:26 AM
I have the exact same board and I'm using Gskill 2133mhz sticks. No problems at all. Currently running memory at 1733MHz CL 9-9-9 and the identical overclock to yours. :)
No link at the end fo crosshair IV ZZLEE Suggestions & Feedback 1 August 29, 2010 07:32 PM
Crosshair III or IV? Keltron 3030 CPU's and Motherboards 2 April 16, 2010 11:33 AM
Crosshair Flashing Bios Luckk CPU's and Motherboards 0 December 26, 2009 12:40 PM
Crosshair III Really That Good? Luckk CPU's and Motherboards 27 November 26, 2009 03:30 PM
crosshair III worth it? muffler CPU's and Motherboards 3 August 20, 2009 02:41 PM
