Originally Posted by SKYMTL Here are the issues:
- 2011 processors will be ultra expensive. These are NOT meant to replace Sandy Bridge but rather introduce Extreme Edition SB processors
- Bulldozer is meant and designed to compete with Intel's LGA1366; an architecture that's on its last legs.
IMO, you should grab a 2600K and be happy. |
woah, they gave you a sample to play with?
Originally Posted by Eldonko As an owner of both a 2600k and a 2500k I have to disagree with that. 2600k is binned a lot better and thus on average should oc a lot better than a 2500k. Worth the extra $$ when overclocking + you get HT which is a bonus. If you are looking for a basic OC then sure 2500k but if you are looking to max out a chip or go for 5Ghz I would go 2600k. Just my 2c  |
flip a coin, those are your chances. plus some peeps disable ht to get a bit more :D
