For motherboards, find out which features you'll actually use in the lifetime of your PC and get a board that has all those features but not much more than that. Motherboards aren't as bad as say... power supplies if you cheap out (cheap power supplies are hazardous). Newegg's search has a good number of filters to get boards with specific features.
If you are going to use a higher end CPU (e.g. Phenom 955/965/975 or six cores), look for a board with MOSFET heat sinks and an 8-pin power connector and that should last you longer.
I see you put two ASUS boards in your comparison so it looks like you already know to look for brands which have half-decent support. I've only used ASUS, Gigabyte, and Intel for boards myself.
__________________ "The computer programmer says they should drive the car around the block and see if the tire fixes itself." [src] |
