Old June 10, 2011, 06:02 AM
Default Asus P8Z68-V: What BIOS settings are enabled/disabled by TPU/EPU switch?
Asus P8Z68-V PRO
What BIOS settings are enabled/disabled by the physical TPU and EPU switches on the motherboard? The manual doesn't say.
Old June 10, 2011, 06:14 AM
TPU will OC your PC and EPU will down clock it
Old June 10, 2011, 06:27 AM
I know, but what specific settings are changed in the BIOS?
Also, with the physical TPU and EPU switches OFF, can I still have access to enable said settings in the BIOS?
I'm trying to figure out if I have a bad motherboard, because even with the TPU switch OFF, the motherboard still tries to overclock when I "load optimized defaults" in the BIOS.
Old June 10, 2011, 07:45 AM
Eldonko's Avatar
Hardware Canucks Reviewer
With opt defaults turbo is enabled so if it is just the multi going up by 1 or 2 it is turbo.
Old June 10, 2011, 08:11 AM
With optimized defaults and TPU/EPU off, I am getting BCLK = 104, turbo multiplier = 43. Same thing with TPU/EPU on. Is this normal?
Old June 10, 2011, 08:14 AM
Eldonko's Avatar
OC Tuner is on. Clear cmos, load opt defaults, and you should be good. That or just keep the auto OC, it will be nice and stable with 2600k.
Old June 10, 2011, 08:25 AM
How do I turn off OC Tuner? The only options I see in the BIOS are "OK" and "Cancel". When I select "OK", the system reboots several times (I assume it is checking to see the optimal overclock). When I select "Cancel", nothing happens.
Old June 10, 2011, 08:27 AM
Eldonko's Avatar
You turn it off by clearing cmos and loading defaults.
Old June 10, 2011, 08:36 AM
I tried it but the same overclocked BCLK and turbo multi. values are getting loaded. I don't understand how OC Tuner is tied to the TPU/EPU switch. I thought disabling TPU should disable any OC'ing?
Old June 10, 2011, 08:42 AM
Unplug the PC and remove the battery and short the connector on the board for few sec. More than often I found that those Cmos reset button don’t do the expected job, especially with dual Bios
ASUS Announces P8Z68 Series and Maximus IV Gene-Z LGA1155 Motherboards Sam_Reynolds Press Releases & Tech News 0 May 11, 2011 09:49 AM
Windows 7 Fails to boot with USB Controller Enabled in bios!!! chibi_man Troubleshooting 17 May 30, 2010 06:45 PM
ASUS Unveiled P5Q Series w/ EPU-Six Engine Hardware Canucks Press Releases & Tech News 0 May 8, 2008 10:23 AM
780i Bios settings help please Quetz Troubleshooting 17 April 27, 2008 01:23 PM
