Old June 10, 2011, 09:02 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Not dual bios LB.
You arent loading an OC profile or anything after cmos clear right?
Old June 10, 2011, 10:33 AM
Originally Posted by Eldonko View Post
Not dual bios LB.
Not loading any OC profiles. I don't even have any setup on the system.
The CMOS seems to get cleared successfully using the jumper, since all the settings I had setup (e.g. RAM timings, etc.) reset to "Auto" afterwards. But as soon as I load optimized defaults, the system reboots a couple of times, and then the BCLK is set to 104, and Multi is set to 44 again.
Does "load optimized defaults" still OC the system even if TPU is off? Or is the OC applied by "load optimized defaults" independent of the TPU?
Eldonko, or anyone else, can I ask for a big favour? Do you have a P8Z68-V PRO you could turn off TPU/EPU, reset CMOS, and load optimized defaults? If the default OC is just something that all of these boards do, then that's fine, but if it is something wrong with my board I would like to know so that I can RMA it.
I'm using a Core i5 2500K, if it makes any difference. I'm thinking that "Load Optimized Defaults" should set BCLK to 100, and Turbo Multi to 34.
Thanks
Old June 10, 2011, 10:43 AM
Eldonko's Avatar
When you load defaults OC Tuner should not be enabled. Are you sure the TPU switch is off (ensure no LED)? If it is on then that is why auto oc is kicking in. If I remember correctly the manual had the TPU switch backwards so you have to make sure there is no led and you will know it is off.
Old June 11, 2011, 09:15 PM
Bingo. Thanks Eldonko! I checked the mobo and sure enough, the TPU light was on and the EPU light was off. I switched off the TPU and the defaults now correctly load non OC'd settings.
Thanks again!
Old June 13, 2011, 09:24 AM
Eldonko's Avatar
No problem. They have the switch backwards in the manual so go by the LEDs. cheers
Old November 22, 2011, 06:02 AM
Trial Member
I had that problem yesterday and noticed that manual was back to front for these setting.
If i turn off the TPU/EPU can I still manually overclock? Since I did read somewhere (Can't find it now) that either the TPU or EPU when enabled for OC'ing can cause instability problem.
Old August 4, 2013, 02:06 AM
Trial Member
I have 3 P8P67 LE motherboards 1 of which has the TPU switch itself in backwards. The other 2 match the manual.
ASUS Announces P8Z68 Series and Maximus IV Gene-Z LGA1155 Motherboards Sam_Reynolds Press Releases & Tech News 0 May 11, 2011 09:49 AM
Windows 7 Fails to boot with USB Controller Enabled in bios!!! chibi_man Troubleshooting 17 May 30, 2010 06:45 PM
ASUS Unveiled P5Q Series w/ EPU-Six Engine Hardware Canucks Press Releases & Tech News 0 May 8, 2008 10:23 AM
780i Bios settings help please Quetz Troubleshooting 17 April 27, 2008 01:23 PM
