LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old February 3, 2008, 12:18 AM
SugarJ's Avatar
Level up: 36% Level up: 36% Level up: 36%
Level: 14 - 374 points to level up
Default GA-P35-DS3L & OCZ2P8004GK = Trouble
Anyone else running the above mobo and OCZ Platinum 2x2g ddr2-800?
I bought this memory "unopened" from a fellow member, and I can't get the board to POST with only this memory in it. The only way I can get the system up is to leave my G-Skills in pos 1&3 and put the OCZ in pos 2&4. I've tried putting them on board 1 at a time, that doesn't work either. I was putting the OCZ in there in prep for my trial transistion to Vista 64bit. (And they're shiny, look very nice).
I've manually set timings to 5-5-5-15(I know it's rated at 5-4-4-15), bumped the voltage to 2.2V, set the FSB to 400 with 2.0 mult. This should work, shouldn't it? I know these are rated at 2.1V and my board defaults to 1.8V.
Intel E8400 Biostar Tpower I45 Diamond HD4870 512mb G-Skill DDR2-1000 4GB Creative Xtreme Audio PC P&C 750W Quad Silencer Antec 900 Logitech G-15, G-5
WC Loop: Swiftech Apogee GTZ Danger Den CPX-Pro, Maze 4 GPU Black Ice GT Stealth 240 Rad
Old February 3, 2008, 12:22 AM
BALISTX's Avatar
Level up: 56% Level up: 56% Level up: 56%
Level: 21 - 538 points to level up
I find OCZ are finicky when it comes to Gigabyte boards. Have you tested the ram in a different board? If you don't have a different board, what about testing them in a friend's board.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
BALISTX.com
Old February 3, 2008, 07:02 AM
3.0charlie's Avatar
I've matched many times OCZ sticks and Gigabyte boards without any problems - and the manual setup you did should work. If that still won't allow POST, 2 more options: change timings to Auto, and if that still doesn't work, default back to stock settings (no oc) and try it. You have to find a way to run Memtest86+ on those sticks, one at a time if you can.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old February 3, 2008, 10:21 AM
SugarJ's Avatar
Ya, I tried them in my Asus P5N-E, had problems there too. Going to try to find someone local running OCZ Platinums to see if they will drop in their board and work. If I can't I'll take them to NCIX to see if they can test them there (came from there originally, still got packaging with SKU sticker). If I knew these things worked 100% then I can probably find a work-around.
Old February 3, 2008, 10:35 AM
SugarJ's Avatar
I'll try setting to Auto timings and dropping back to stock speeds, but I'm going to leave the dimm at 2.1V because I've seen people have problems with lower voltages. I'm going to leave these sticks in slots 2 & 4 because the machine posts with them there now with the G-Skills in place. If that doesn't work, I'll try 1 G-skill and 1 OCZ set to same timings.
I've been able to get Memtest 86 running, not plus, from my Ultimate Boot CD, but it craps out at 4GB. Not sure if this is a Memtest limitation or not.
Thanks for all your help 3.0Charlie and BALISTIX, you guys have been an invaluable resource over the last couple of days.
Old February 3, 2008, 11:13 AM
3.0charlie's Avatar
No problem - Jerry and I both have that board, and we know it inside-out.
Old February 3, 2008, 12:19 PM
SugarJ's Avatar
I think I'm toast. I can't get these OCZ's to post individually or together in any slots, or in a 1 of each Gskill and OCZ configuration. If the machine does POST, it dies right at the memory announcement. (Says Mem- then artifacts)
Tonight I'll pull my 512mb G-skills out of Lindsey's machine, and see if I can get the OCZ's to boot in the same configuration I had with the 1Gb Gskill sticks. That would give me a 5Gb config that I should be able to test with Memtest 86.
If I can't get that to work, or get them to work in the Asus board, I'm taking them to NCIX for testing.
On a positive note, I am really enjoying the E8400. (Go to your happy place Gord, think positive thoughts)
Old February 3, 2008, 01:24 PM
3.0charlie's Avatar
With all the differesnt tests and configs you've tried, you should be confident to return those on the basis of being defective.
Old February 3, 2008, 02:08 PM
BALISTX's Avatar
I agree with John, it looks like those sticks are defective. Sine you have the packaging just return them to NCIX.
[Heatware]
BALISTX.com
Old February 4, 2008, 02:31 PM
SugarJ's Avatar
They're going back. The guy I bought them from emailed me a copy of the invoice. All should be good.
Thanks guys.
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/cpus-motherboards/4396-ga-p35-ds3l-ocz2p8004gk-trouble.html
Posted By For Type Date
No POST with GA-P35-DS3L - Rage3D Discussion Area This thread Refback August 25, 2008 02:25 AM
BD remote trouble on my PS3 ebdoradz Gaming 0 January 6, 2008 07:46 PM
PS3 wi-fi trouble ebdoradz Networking 8 December 8, 2007 06:12 PM
Trouble with fan controller. chibi_man Troubleshooting 2 September 24, 2007 07:49 PM
Help! Trouble!..pushing the FSB to high! francois methot Overclocking, Tweaking and Benchmarking 23 March 11, 2007 11:16 AM
