Old June 5, 2011, 09:54 AM
Wintegrity's Avatar
Default 680i Finally died! Need a replacement
Heh all... Just had my EVGA 680i crap out on me. Looking for a replacement with DDR2 1066 support. Must be able to OC my E6600. Balanced performance and cost as I don't want to invest too much more into this box. Maybe keep it for another year or so.
Any ideas or boards for sale?
Thanks in advance!
Old June 5, 2011, 10:04 AM
Coach's Avatar
RMA the board?
Old June 5, 2011, 10:05 AM
Coach's Avatar
shipping will be about ~20 bucks and it is hard to find another board for that little
Old June 5, 2011, 10:23 AM
MARSTG's Avatar
Biostar G31-M7G is the only mobo on newegg that still supports DDR2 1066. You will have more options if you lower the ram speed to 800. Cost is 40$, Intel G31
Old June 5, 2011, 10:34 AM
yycraven's Avatar
Well how much do you want to spend.
Old June 5, 2011, 06:25 PM
Wintegrity's Avatar
Maybe $100 or so...
Old June 5, 2011, 06:26 PM
Wintegrity's Avatar
Originally Posted by Phill View Post
RMA the board?
I read a post on another forum that stated EVGA were no longer accepting returns for this board?
Old June 5, 2011, 06:30 PM
Wintegrity's Avatar
I would consider a decent used board as well ...
Thanks.
Old June 5, 2011, 06:35 PM
Coach's Avatar
what? I still have a 790i that I ended up with after a zillion 680i RMAs and I thought the lifetime warranty on them meant that although you may not get the same board back you would get something.... please link to that thread
Old June 6, 2011, 08:02 AM
yycraven's Avatar
Products sent in for RMA will be repaired or replaced with a product of equal or greater performance if an exact replacement is not available.
Now I do not know if you have the board registered under your name or not, if its under your name you should be able to RMA it from what is written under eVGA warranty on there site.
Give them a call and see what they say.
New Build just died Steve Jones23 New Builds 11 May 21, 2011 03:37 PM
I think my PSU died...? Pax Power Supplies 6 February 12, 2010 12:38 PM
My mobo died- What do I do? Cowboy CPU's and Motherboards 22 September 7, 2009 04:49 PM
Wifes PC died? Scratch Troubleshooting 10 March 23, 2009 10:09 AM
Old rig died on me? Delavan Troubleshooting 5 January 20, 2009 05:48 AM
