Old May 19, 2011, 08:30 PM
Default Q6600 tweaking
So, I recently re-built my old system, all the same old parts and now, instead of overclocking the Q6600, I'm undervolting it. While doing this, my most stable voltage so far is 1.1500v. The chips VID is 1.3250v. So, I compared the two voltages using 3Dmark06 to make sure I'm not losing any performance by lowering the voltage, and instead of losing marks, I gained them? Went from 11137 3DMarks, 3346 CPU score, to 11393 3DMarks, 3382 CPU score.
The low voltage has been tested with IntelBurnTest, so my question is, why is my system more stable at the lower voltage?
Old May 19, 2011, 09:17 PM
francisw19's Avatar
Do you get the same results running the benchmark again?
Old May 20, 2011, 08:27 AM
Yup, same results. Ran it 3 times and got 11393.
Tweaking Xp on an old PC botat29 O/S's, Drivers & General Software 29 February 3, 2011 01:21 PM
gpu voltage tweaking.. gon_freecs Troubleshooting 3 February 1, 2011 08:01 AM
OC Tweaking Spreadsheet misterlarry Overclocking, Tweaking and Benchmarking 0 September 3, 2008 04:44 PM
Tweaking Task Manager Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 8 February 6, 2008 11:13 PM
