Old May 14, 2011, 10:21 AM
Default gigabyte ga-p67a-ud5-b3 phase light LEDs
Hi there,
I just recently purchased the mobo that is in the title of this post and it has 4 LEDs that light up upon start up then they shut down. I read through the mobo manual but it doesnt actually explain what these phase lights do. Does anyone know what they mean? I can't find a good answer through Google or this website's search bar
Old May 14, 2011, 06:22 PM
basically it tells you how many are working
if you in stall the giga software, you can turn them on or off
and also use the energy saving,quite nice feature.
Old June 8, 2011, 01:10 PM
The theory is that they indicate the number of "power phases" currently in use, that depends on the CPU load, which effectively reflects the power required to operate your CPU at the current load level. That is, the current that needs to be delivered to th CPU. The more current, the more phases are used. Physically, the "phases" correspond to the MOSFET modules in the VRM area of the motherboard. You can see the inductor coils packed in grey boxes. IIRC, in the P67A-UD5 every MOSFET (and thus phase) corresponds to 2 coils.
Hope that helps. You can find similar LEDs on the high-end MSI video cards. Fun to see them go up and down, really :) And they give you a nice light effect, too. :D
H60 + P67A-UD5-B3 enaberif Troubleshooting 11 April 24, 2011 06:37 AM
Gigabyte P67A-UD7-B3 Sandy Bridge Motherboard Review Comment Thread SKYMTL CPU's and Motherboards 21 April 20, 2011 03:33 PM
Gigabyte P67A-UD7 & P67A-UD4 Sandy Bridge Motherboards Preview Comment Thread SKYMTL CPU's and Motherboards 18 December 29, 2010 08:17 PM
